Question about Ovens
Need a instruction manual for a confection oven ac930acn
2 Suggested Answers
SOURCE: I need a manual for a Welbilt Confection Toaster Oven
I have manual for welbilt model cv6311
Posted on Feb 02, 2010
Co confection oven door will not stay close . model number 1418342L
Try cleaning and removing the door, it may be causing the hinges some problem inside .
hope this is helpful
John
May 31, 2011 | Ovens
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Need fitting instructions to replace door hinges as manual misplaced. thank you.
The user manual probably wont have instructions for replacing your door hinges anyway. The service manual would, but they don't generally supply those with the oven.
I'd need to know the brand and model of your oven in order to give advice on fitting, as would any other expert here. Some ovens have sprung tension hinges, others have pivot/swing hinges.
Oct 10, 2010 | Neff B1421 Electric Single Oven
Jan 31, 2010 | Ovens
GE Profile Convection Problem
with GE
SHORTED OVEN SENSOR CIRCUIT
if your comfortable taking the range out of the box, it is a pretty easy repair. The oven sensor is a small tube in the range that "sences" temp.
although it could be the erc, its more than likely the sonsor itself.
it is on the back wall and has to be unplugged from the back to be removed
there are two screws that hold it on the back wall
put the new one in and you should be ready to go
goto appliancepartspros.com
type in your modle number and look in the cavity section
your looking for the oven sensor
they usually run around 20-30 dollars
Oct 17, 2009 | GE Profile 30" Built-In Single Electric...
Ovens Logo
15 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
