Question about Panasonic NV-GS15 Mini DV Digital Camcorder
BLACK Lines and having to reset.
An intermittent fault. Sometimes there are horizontal black lines across the playback LCD screen and after resetting and ejecting and putting back in the tape they are not there ...until they reapear the next time the Camera is used. Camera is under 3 years old and had been kept away from Dust,Dirt and water.Well protected against knocks and bumps. Ray
    Champion:
  • 221 Answers
I assume that the 'black lines' are 5 bars of dark video spaced equally across the screen. this is a symptom of dirty heads. use a mini DV cleaning tape, and the problem should go away.
Posted on Sep 25, 2007
Try cleaning the lens with lens cleaning solutions avalable in the market.. The headclening cassette may not help in all situation Better to clean the lens after dissassembing the camera... Regards Shafeeq
Posted on Jul 04, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
Samsung LNT4671F 46" HDTV
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 21, 2016 | Samsung Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
How to repair my Samsung Plasma, it has horizontal black lines across the screen.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 12, 2015 | Samsung PN50C450 50 in. TV
How to factory reset with only remote, while screen remains black w/ 5 thin horizontal colored lines streaking. Why is screen black?
Without a proper screen, you can't do a factory reset to this set. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 07, 2014 | Samsung PN42B450 Plasma TV
Horizontal Lines and distortion
It sounds that the T'Con board has the fault. Check all the cable connections to LCD pane to T'Con board for firmness.
Jan 03, 2013 | Televison & Video
I have two sets of black horizontal lines going across my Sony Bravia KDL-52Z5100. If you make the picture smaller the lines extend into the black area that is not part of the picture. After the TV warms...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem...
Aug 06, 2011 | Televison & Video
I have a Samsung model HLS5085WX/XAA. We have black specks all over screen and black horizontal lines approx 4 inches a part all the way across the screen
All Plasma and LCD ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them. Good luck in rectifying the fault.
May 17, 2011 | Televison & Video
Focusing
The lines appear to be a ccd problem:
http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html
May 18, 2008 | Nikon Coolpix 5700 Digital Camera
Horizontal Black Lines on palmOne z22
hi, sounds like the screen has a bad connection. Are the horiz lines the same shade all the way across?
Apr 24, 2007 | Palm Z22 Handheld
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
398 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
