Question about Echo Cs-4400 Chain Saw Operators Manual
What is gas to oil ratio for echo cs 4400 chain saw
3 Suggested Answers
  • 398 Answers
SOURCE: need to know oil to gas ratio mix for echo 510 evl chain saw
50:1 or of its old 100:1
Posted on Mar 20, 2009
  • 2239 Answers
SOURCE: I have an Echo CS-3450 16" Chain saw that starts
This is classic fuel starvation, it needs to run a little rich when free running, when it goes under load it needs the extra fuel to keep it going, if you have replaced the fuel filter, and the fuel hoses are good ( no leaks, or cracks in the pipe, give the pipe a tug to see if fuel squirts out ) then there is dirt in the main fuel screen under the pump diaphram, remove the carb, remove the alloy pump cover, normally held with a single screw, under here will be a gasket, and a pump diaphram, in that order, pressed into the carb is a very fine screen, this should be replaced, or at least cleaned, check the condition of the diaphram, this should be supple not hardened, rebuild and try again, the H screw on the side of the carb controls fuel to the main jet, if need be increase ( screw out ) 1/4 turn.Somewhere from the tank will be a breather, this allows air into the tank to stop a vacume occuring, to check this slacken the filer cap when the machine starts to die, if it picks up again it is a breather issue.
Posted on Jul 18, 2011
Why does derate lose power?
OK things to check. Gas/Oil mixture make sure you mix it in right amount. Be sure chain is NOT too tight. Now be sure to let the saw do the work . if you put too much pressure on it or,the chain is dull , the saw will loose power. Let me know how it goes.
Dec 03, 2015 | Echo Cs-400 18" Gas Chainsaw 40.2cc Sealed
Oil ratio for my Swedish made jonsered chain saw model 625=2
Using only a high quality 2 cycle oil mix 2.6 ounces of oil to a gallon of fresh gas.
Sep 30, 2014 | Oregon Jonsered 13" Chain Saw Repl. Chain...
Which is the gas and which is the oil plug
The forward one is the fuel, and the rear (near the handle) is the oil.
Jul 07, 2014 | Echo Chain Saw Service Repair Manual...
Echo chain saw won't start tried new gas ran then quit plug is clean
check air, gas and oil ratio.... check high voltage to plug..
Sep 21, 2013 | Echo Garden
What is the oil to petrol ratio for an Echo Saw?
Oil / gas should be in the ratio 1 to 50 or 2%.
This is 20mL in 1 litre or 2.6 fl oz per US gallon
Aug 01, 2011 | Echo CS400 18" Chain Saw
What is gas oil ratio for a 16 inch poulan chain saw
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is correct fuel mixture for Echo CS 6701 Chain saw?
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
Lou
May 08, 2010 | Echo CS600P Gas Chainsaw 20 Inch
Echo CS-302 chain saw with no instructions (Inherited)
the echo cs302 is equiped with an automatic oiler that lubricates when the engine is running the manual states the unit runs on a 20:1 mixture 89 octane fuel with 6.4 oz of tcw3 oil per gallon
Apr 10, 2009 | Echo Garden
Open Questions:
Echo Cs-4400 Chain Saw Operators Manual Logo
212 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
