Question about GE Dryers
Dbvh512efoww what does code 000 mean on ge dryer
Need codes
  • 111 Answers
SOURCE: What does display code 1H on GE Profile dryer mean?
It means you have it set for a 1 (one) hour delay start
Posted on Dec 16, 2008
hunter19_46m
  • 7482 Answers
SOURCE: GE dryer model dbvh512efoww has burning smell
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your burning smell may be coming from your belt or an excess build up of lint in the exaust.
You will need to remove the vent exaust hose and clean it out, and also check the lint filter and discharge that is going to the hose for lint buildup.
Your other problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Oct 28, 2009
heatman101
  • 43501 Answers
SOURCE: GE dryer makes loud huming sound wont start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 26, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have lots of lint
Hi rstebly...
Sometimes the problem is with the lint filter itself...
If you use "dryer sheets" they can plug up the holes in the lint filter with a kind of waxy substance and that will impair the air getting thru the filter causing the lint and air to find another way out, not thru the filter but thru the machine.
I would suggest you take the filter out and wash/scrub, lightly it in hot soapy water, let dry, then reinstall the filter.
You should also check the blower /blower tube and the inside of your dryer for lint buildup also, as lint buildup can cause dryer fires.
Hopefully this will solve your problem
Free Answer...Please rate me
Posted on Apr 28, 2011
oldTech2332
  • 2341 Answers
SOURCE: The dryer makes an electrical
it could be the motor ,or perhaps the belt is broke but sounds more like the motor since ge uses a belt switch so if the belt were broke it would not even make the buzzing sound.
get some help from someone in the house and set the timer to any cycle,open the door and push in the door switch then have the other person engage the start switch while you rotate the drum if the dryer runs like that but wont start with the door closed and engaging the start switch as normal the start winding is bad on the motor and the motor would need to be replaced and the cost of that is about equal to a new dryer
Good luck!!
Posted on Jul 19, 2011
What do the "T" error codes mean in regards to GE electric dryer model # DCVH515EFOWW
YOU must see you instruction manual section troubleshooting and Fix it.
if you do not have download the instruction manual from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 19, 2012 | GE Dryers
I need the code for a ge tv and I have a RCA univeral remote what is the code
GE really is RCA,.
GE TV Codes-000-054-003-004-006-022-052-055-087-164-165-166-167-168-181-196-213
Jul 04, 2011 | RCA RCR312W Remote Control
I have lots of lint that gets trapped under and all around lint filter and it is very hard to get out - why is it not being contained? GE Dryer DBVH512EFOWW front load.
Hi rstebly...
Apr 28, 2011 | GE DBVH512EFWW Dryer
How do I program my universal remote control for my ge tv model # 19gt357?
Code 000 for GE TV Code 003 for GE TV Code 004 for GE TV Code 006 for GE TV Code 022 for GE TV Code 052 for GE TV Code 054 for GE TV Code 055 for GE TV Code 064 for GE TV Code 087 for GE TV Code 100 for GE TV Code 165 for GE TV Code 166 for GE TV Code 167 for GE TV Code 181 for GE TV Code 203 for GE TV Code 212 for GE TV Code 233 for GE TV try these if these won't work add a 1 in front of the codes to give you a 4 digit code. Good luck
Nov 15, 2010 | GE 19GT357 19" TV
heatman101
May 25, 2010 | Dryers
Good Luck,
I hope this helps
Oct 28, 2009 | GE Dryers
No heat in electric clothes dryer
sounds like the typical heating element problem,which is located behind the drum.
Sep 08, 2009 | Dryers
Need tv code #
GE Codes 000-003-004-006-022-052-054-055-087-164-165-166-167-168-181-196-213
Dec 27, 2008 | GE 25GT240 25" TV
I just hooked up comcast cable to my television(25gt240) and in order to work the tv with cable remote i need the televisions code... can u help?
It may say GE on tv but it is a RCA I use code 000 most of the time ,Codes 000-054-003-004-006-022-052-055-087-164-165-166-167-168-181-196-213
Dec 12, 2008 | GE 25GT240 25" TV
Nov 23, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
