19" Curtis lcd 1992A flatscreen TV. Watching a DVD movie & a static sound started. The sound began to intermit then no sound at all. TV is 1 year old, I reset it, checked the sound mode, etc. Still no sound.
SOURCE: crackling sound through speakers while watching dvd movie
Yamaha Rx-V361 Firmware Upgrade, A/V-Receiver/-Verstärker - HIFI-FORUM
Posted on Jun 18, 2008
SOURCE: Tevion 19 LCD TV Model Number 1961HDT
eh, that should be 0871 663 1540
Posted on Jun 25, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
SOURCE: No picture No sound
how did you remove the stand attached to the tv? But i have heard of this happening before too..They tend to just die..
Posted on Mar 03, 2009
  • 718 Answers
SOURCE: sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Posted on Mar 10, 2009
I think my tv had a power surge tv went to static then shut off when i was watching a movie on my dvd
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 03, 2014 | Element Skateboards Element ELGFW551...
No sound when watching tv but have sound when playing the video game or watching a dvd
Is the mute activated or any buttons on the remote jammed? If the color system/format has changed when you connected it to games, it has to be changed back to what it was, making it suitable for TV reception.
Aug 26, 2012 | Curtis LCD3227A 32-inch LCD TV
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Sound is okay watching tv on hdtv - but crackles with dvd playing
If your DVD player supports HDMI or OPTICAL / DIGITAL audio then I would take a look at swapping to those type of connection first. This would help eliminate bad cords / connectors / electrical interference from other sources
Your TV has two hdmi inputs and optical so you have a choice
Aug 08, 2009 | Vizio GV42L 42 in. LCD Television
My vizio flatscreen lcd has pic but will not play sound through the tv output, however it will pay sound when watching a dvd - just not when watching satellite
Use the cables connecting the DVD and connect the satelite.
If everything works OK, then check and replace the cables for the Satellite.
If the sound is still No Good, check the audio settings on the satellite
You may connect the DVD using the Satellite cables as a check as well
Jun 05, 2009 | Televison & Video
LCD TV screen goes black but sound remains.
i have the same exact tv and the same exact problem my problem started about 3 months after i bought it and since i didnt have the receipt couldnt do anything about it. i wish i could find a solution to this problem as well its so annoying.
Mar 28, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
TV is not coming on
If I understand your problem correctly, it sounds like the unit is not coming on... If this is correct, then replace the 3 capacitors on the output side of the power supply. There are 2@1000uF @25V and 1 smaller one which is 220uF@25V.
I think the part number on the board is marked as WX-15/19/20Power-01...
This worked on a 19 curtis LCDVD191
Hope this helps...
Feb 11, 2009 | Curtis LCDVD151A 15 in. HDTV LCD TV TV/DVD...
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
