Question about T-Mobile Sidekick II
My problem is with the sidekick III, it wont charge, What should I Do?
Whenever I plug The charger to my sidekick III it doesnt charge, but when my friend charges his it does. Nothings wrong with the battery. The charger light wont even turn on. What should I do?
  • Anonymous Jan 11, 2009
    my side kick two wont charge at all
  • mezmarize Feb 24, 2009
    my side kick wont turn on, it only says that the battery is to low, and that it has to charge up a little before it turns on, i let it charge for a little and still nothing. i want it to turn on.
Dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Posted on Feb 26, 2009
I had the same problem with my sidekick3 not charging or turning on i went to t-gay-mobile and they told me it was shot but i bought a new charger and it works now BUT IF THAT DOESNT WORK GET THE DOCKING STATION THAT CHARGES UR BATTERY SEPERATE I SWEAR IT WILL WORK BUT IF IT DOESNT ITS UR PHONE IT SELF
Posted on Mar 19, 2008
Sounds like there may be a problem internally with your sidekick. must be a short somewhere within the sidekick itself. have you tried using a different charger? if its not the charger then there is a short in the sidekick itself.
Posted on Jun 10, 2007
My phone doesnt charge
check your charger.if your charger is working get your phone checked from your respective customer care center as it might have a charging pin problem.
Oct 06, 2009 | T-Mobile Sidekick II
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Jun 29, 2009 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 wont charge
There might be something wrong with the charger or you can use a different outlet.
But if there is something wrong with the charger i would suggest to get a new one (:
Mar 05, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick wont charge
wakesk8er02
The sidekick 3 has a known issue with the charging port going bad. The orange light will usually come on but it doesn't charge the battery.
you can try www.cellulardr.com or you can do a work around that will cost less.
Most people will buy a cradle charge that has a built in spare battery charging slot. This allows you to charge the battery seprate form the phone. ?It is about 25 dollars on ebay. Its also a good idea to get a spare battery so you can have one charging at all times.
Sidekick 3 Spare Battery Charger
Sidekick 3 Batteries
Jul 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 wont turn on
if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick II Logo
443 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
