Question about Toshiba 32AV500U 32 in. LCD HDTV
My Toshiba 46g300u1 has sound but no picture. It will display a picture when I play a movie on my Blue Ray. I have checked the cords and inputs. It worked last night and no cords or inputs were switched. I think my 2 year old got a hold of the remote. How do I fix this?
  • 3 Answers
SOURCE: No picture, sound works. Screen flickering
That problem is caused by the Y Sustainer board.
Posted on Apr 05, 2008
SOURCE: No picture, just sound
No new video card required. I just reset the television by holding the on/off button for five seconds (yellow light on front panel blinks repeatedly). I then cycled power using the remote control and my picture came back. Worked for me. Hope it works for you.
Posted on Jul 16, 2008
  • 223 Answers
SOURCE: Toshiba 50hp66
I think that the pop you heard was an electrolytic capacitor blowing its top on the picture frame board. If you are able to check this for yourself by looking on the board for the one/s with a bulging top or are a brownish/black colour like something has caught fire. And also in this situation smell can be of great help as it will smell burnt out but PLEASE before putting your nose or anything else in the tv take all necessary precautions against electric shock and discharge any electrolytic capacitors in the vicinity. If you are not able to do this yourself find a competant technician. Hope this helps.
Posted on Oct 07, 2008
SOURCE: Toshiba Regza sound but no picture
I had the same problem last night - sound but no picture form any of the inputs - DVD, VCR, FIOS or antenna. I could still see the TV menu. If you go to the TV menu - you can go to the settings (far right top), from there you can choose to restore factory settings, usually needs a code - 0000 (if you did not choose a different one), select yes when prompted if you want to restore factory defaults. This brought my picture back. I lost all of my picture preferences i had set - but at least I got a picture! I hope this helps!!
Marilyn
Posted on Apr 02, 2009
  • 814 Answers
SOURCE: no sound on my Toshiba Regza 42HL167
Found this troubleshooting method on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
Models: 20DL77, 20HLK67, 26HL47, 32HL17, 37HL17, 42HL17, 26HL37, 32HL37, 20HL67, 26HL67, 32HL67, 37HL67,
42HL167, 42HL67, 47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00128
1. Please check your connections and make sure if you are using COMPOSITE “yellow, white, and red cables”, SVIDEO,
with “white, and red” or Color Stream COMPONENT “green, blue, red, white and red cables,” that the white
and red cables which are used for audio are plugged in securely into the same inputs as the video.
If your connections are secure, the station may have broadcast difficulties. Try a different channel.
2. If you are using the coax cable from the wall, press the “ENTER” button on the middle of the remote. If the
information provided shows that you have SAP selected we will need to change it to STEREO or MONO. To do
this, we will need to press the “MENU” button, and use the RIGHT or LEFT arrow keys to highlight the AUDIO
menu. Next we will need to use the DOWN arrow to select AUDIO SETUP press “ENTER” and then arrow down to
MTS and use the RIGHT arrow to select stereo.
3. If you have a cable box or satellite receiver, please make sure the TV’s volume, as well as the box’s, volume is
turned up sufficiently.
4. The station may have broadcast difficulties. Try another channel.
5. The sound may be muted. Press VOLUME.
6. If you still have problems after following these steps please contact Customer Solutions at 1800-631-3811 Monday
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811. I hope this helps you with your problem.
Posted on May 17, 2009
My Toshiba won't play blue ray movies
possible cause is hardware compatibility. But if your unit was been played it before, then try re-scan your system with antivirus.
Sep 09, 2011 | Toshiba Televison & Video
Could not play blu-ray disc movie - ? problem w/ display and or ? copyright
to play blue-ray you need to have a blue-ray rom if you have then check if the movie is trully blue-ray, there is not a display problem or copyright.
Nov 28, 2009 | Sony VAIO Notebook
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Blue ray player
make sure you have all the cords plugged in and in the right place. especially the red, white, and yellow cords. they go in a certain order depending upon the tv.
Dec 26, 2008 | Video Game Consoles & Games
Won't play ANY movies
separate the plug on the other appliance,check if the trouble is dvd or tv by connect other input device like game console or dvd.
Feb 11, 2008 | RCA DRC8052N DVD Recorder
PS3 - green Bar when playing blue ray on my 50" Phillips Plasma
Green bar or border is due to wrong AV Setting. To resolve this just insert the Blue-Ray DVD and begin to play. Press the Triangle button and select "AV Setting", in AV Setting change Video Output to RGB.
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
DVD plays with sound but no picture
Have you checked the unit on another input or another set to eleminate the video input? also try the video cable. If theres sound and no video and you tryed then the video output amp in the player has a problem and the only way to fix this would be with a schematic and a scope to trace out the video signal. Good luck
May 25, 2006 | Toshiba SD-230 DVD Player
Toshiba 32AV500U 32 in. LCD HDTV Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
