EZ Vinyl Converter produces file that doesn't work
I just got the Ion EZ Vinyl Converter for Christmas. I use their recommended software and it creates a file in iTunes. However, when I try to play the file, it makes no sound even though iTunes shows the file playing. I checked the "Gain" setting on the back and saw it was at the minimum, so I set it about midway. However, the recording I made after that adjustment still disn't work.
Any ideas?
  • Anonymous Jan 28, 2009
    i have the Numark turntable with the EZ vinyl converter, and i had exactly the same problem. once the song is exported to itunes, it has no volume.
  • kpthomas55 Feb 05, 2009
    Guest, I think you need a new cartridge. That's what I determined when I was on the phone with a tech. I'm still waiting to receive it.
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
Posted on Feb 05, 2009
  • easymack Sep 13, 2010
    Thanks much Storminnorman. You saved me at least an hour and its equivalent in frustration.
During recording I get noise. The noise doesn't go away until I close the E Z Converter.
Posted on Dec 20, 2009
    Problem Solver:
  • 8 Answers
Storminorman is right . ION added a fix to new shipments of turntables advising to reset to default sound device after installing the turntable which changes the sound device to USB Audio codec. ITunes needs the original sound device to play what you recorded.
On another note You may need to download an upgrade to EZ Vinyl Converter 4.1 if you have trouble exporting to ITUNES. It works but not completely, only some tracks export and others duplicate. This is a real crappy product. Check out LPRIPPER.COM it's expensive but gets good reviews.
Posted on Jan 08, 2010
Has anyone come up with a solution to this problem please
Posted on Dec 07, 2009
  • Storminorman Oct 22, 2010
    connect player direct to USB port on computer not through a usb hub
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
Nov 16, 2017 | Numark ttUSB Turntable
EZ Vinyl converter does not work reliably I need an alternative, Audacity is too complex
I use Magix Audio Cleaning Lab. There are different versions of it with various prices, but you can find one cheap enough of Amazon
Feb 24, 2011 | ION Audio iTTUSB Turntable
I have upgraded iTunes to 10.1.1 and now EZ Vinyl converter v2 does not recognise that itunes is installed. How do I resolve this?
Hi.
I would recomend uninstalling the vinyl software, restarting then re-installing the vinyl software.
Jan 16, 2011 | ION Audio iTTUSB Turntable
1-I'm recorded my music 10-track on step 3 on EZ Vinyl Converter. 2-On step 5 export recording to iTunes take tolong to complete. 3-I'm access iTunes Music library. I see only 3 music track. 4-Can you...
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
Nov 29, 2010 | ION Audio TTUSB10 Turntable
I am having a problem recording more than 1 track on my new ION tape express cassette conversion system. I was instructed by ION to uninstall the previous ez vinyl converter software and re-install the new...
I have the same problem and do not know the answer. Was searching here for an answer to my problem. Only a small part, 4 tracks in fact, about 5 minutes from a 30 minutes tape are imported to Itunes. where is the solution because it seemed the computer was recording the whole tape without problem. Where is the data gone. Can someone explain. Nico
Jan 12, 2010 | ION Audio TAPE2PC Single Cassette Deck
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Jul 25, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Need drivers for my ION Audio USB Turntable
Hello
USB audio turntable can be found on this site: Driver Update. have a nice day
Jun 22, 2009 | ION Audio iTTUSB Turntable
I want to know how to operate iTTUSB.
I think it's plug and play. Plug the record player in the usb slot, let your computer find it, turn on your recording program, drop the needle on the record.
Apr 03, 2009 | ION Audio iTTUSB Turntable
Televison & Video Logo
2,336 people viewed this question
Top Televison & Video Experts
