Question about FIC VC 11 Motherboard
Fic vc 11 pci slot
LAN card sometimes works, but often needs driver reinstall... Hardware device wizard will nor recognize anything but "Ethernet Controller" on its own... Reinstalling driver puts LAN card back in use... Recently LAN card does not recognize connection to router, always detecting "cable unplugged"... Wireless card recognized correctly, and driver installed, however not scanning for networks... Is there some firmware fix, or motherboard is scrap?
3 Suggested Answers
  • 177 Answers
SOURCE: ethernet controller driver for P4M 915G/PD1
I think it realtek LAN card. You can download the driver from the following link and try.
Posted on Nov 25, 2008
  • 1959 Answers
SOURCE: Need Ethernet controller drivers for FIC P4M-915pd1 motherboard
Download and install UnknownDeviceIdentifier.(its freeware)
Once installed, run the program to identify exactly what ethernet card you have. Then you can either post back to get the driver or go to the manufacturer's site to get it. Best of luck.
Posted on Jul 09, 2009
My ports and my on board LAN are not working my motherboard is ECS PV4MM2..What shoulbe the proble and how can I resolve it.Yahks if you would respond immediately on my problem
Go to Device manager By following this steps
  1. On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
  2. In the System Properties window click the Hardware tab.
  3. In the Hardware tab click the Device Manager button.
Then on left side Search for Yellow question mark on Ethernet controller if it occurs than the problem is that you have to reinstall your LAN drivers which can be Downloaded here
And If there is no Yellow Question Mark then you have to bring a LAN card and insert in PCI Express Slot.
Jan 28, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Reformatted Windows XP does not recognize D-Link wireless adapter
I ran recently across the same problem and solved it by changing the PCI slot where the card was installed... it makes little sense to humans, but apparently make a world of difference to the PC hardware ;)
Assuming you had installed unsuccessfully both Card and Driver you have them (like I did) both on your PC. In such ase, the solution for me was as follows: 1) Turn Off PC 2) Remove the card from the current PCI slot 3) Turn PC back On and remove driver 4) Turn Off PC, remove power cord and wait a minute or two 5) Do not install card yet 6) Turn PC back On and install the driver 7) Turn Off PC remove power cord 8) Install the Wireless card in a different PCI slot THIS IS VERY IMPORTANT!!! Can't be the same slot as where it was installed before!!! Note: If you have none available swap PCI slots or remove a PCI card to free up a different slot for the wireless card... remove a card you need the least and in its place install the Dlink Card. You may want to hold off on installing in a second step the card you have just removed, to be on the "safest" side.
9) Once the card is installed, Power up your PC 10) Once windows will be back up and running the hardware wizard should kick in and tell you that new hardware was found. 11) Follow the on-screen instructions 12) click "Continue Anyway" when XP will warn you that the driver hasn't been signed 13) Installation should be completed after you click Finish at the end of the New Hardware Wizard process 14) Simply go to your wireless networks and make sure all works in order
(I know that this process may sound a bit "anal" in some steps, but I was no longer willing to deal with any possibility of problems of any kind as I was ready to rip that wireless card to shreds!)
I hope this will help those who struggled with reviving an old PC to give to a friend!
Aug 02, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
I think my network card is bad. My internet / email isn't working on my desktop (although it works fine on my laptop). And the computer is not recognizing anything when I type ipconfig. So, i think i need...
since the network card is built onto the motherboard reinstalling the driver would be the best first option.
HERE is the link to the driver.
Broadcom827.exe - Broadcom NetXtreme Gigabit Ethernet driver Version:
Supports: Windows XP
Note: This is the Broadcom NetXtreme Gigabit Ethernet driver for use with the Big Lake, Cortez, and Putton Bay motherboards in Windows XP.
I would try that first.
Apr 14, 2010 | Gateway GX7022E (RBGX7022E) PC Desktop
Where to get pci driver
should be on your install disk that you got with your board
Dec 10, 2009 | ASUS P4PE/L (ASU49J) Motherboard
LAN is not recognizing Internet port
Then you have reinstall *********** boards drivers from its cd.
Oct 25, 2009 | Intel DG31PR Motherboard
How to instlall PCI device driver for integrated ethernet
Check the name of the card or model, download the driver to Internet just search for that? you'll needing to reinstall manually the driver of the PCI adapter to your computer.
Mar 12, 2009 | HP D330 PC Desktop
Ethernet controller driver for P4M 915G/PD1
Nov 25, 2008 | FIC P4M-915PD1 Motherboard
One of two 3com pci gigabit ethernet cards is not working
If you have the driver disk that was distributed with the card , try reinstalling the card drivers first.
If the card is faulty, buy a new pci ethernet adapter and replace it, inserting the ethernet adapter into the pci slot.
After installing install drivers for the new card with the disk that will come with the card.
Ensure that you are logged in as administrator when you reinstall the drivers.
Nov 05, 2008 | SysKonnect Gigabit SK-9843 Network Adapter
Hi Hasan007, download your manual for your FIC VC 11 at this link.
Your board is supported by the Intel chipset 845. Intel is supposed to include the intergrated PCI sound card driver for the, AC97 ICH2 audio controller along with the video controller. This link should get you to the AC97 driver.
Started the ftp here, opening the first folder top of the page.
Once you get the correct driver (Sigmatel/AC97), your sound should work.
Good Luck!
Apr 04, 2008 | FIC VC 11 Motherboard
Lan card
Use a different PCI slot and reinstall the drivers for your LAN card. If this does not fix the problem there may be a compatibility issue between the network card and some other software (eg. irq conflict etc.), or the LAn card may be slightly faulty and have problems on some motherboard.
In this case you can try troubleshooting the problem.
If you cannot find out the problem at a glance, checking in device properties, you may be forced to reinstall Windows. In this case I suggest to just replace the part. The Ethernet (LAN) pci card is quite an inexpensive part, and you can still use this one on a different computer.
Apr 02, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
FIC VC 11 Motherboard Logo
26 people viewed this question
Top FIC Computers & Internet Experts
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
