Question about Philips Magnavox 27MS343S 27" TV
My 37" LCD maganavox tv won't turn on - it blinks green and then eventually will turn solid green and then the tv will come on. This has been happening for a few weeks.
  • Anonymous Apr 25, 2009
    My 37" LCD maganavox tv won't turn on - it blinks green and goes off. Using the remote on button several times and it wiil eventually turn tv on. I have had thus problem twice. Ist time cost $300 dollars for a new powe board and looks like another $3oo dollars. Seems this is a major problem and nothing being done to help it from happening again.
  • Rich64804 May 11, 2010
    My power board does not have these parts. Rich
  • Philips Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
LG 37LC2D will not turn on
mine just did this tonight as well.... no answers yet?
May 09, 2010 | LG DU-37LZ30 37 in. LCD HDTV
I have a Hannspree 37" lcd tv that doesn't come on. When it's off, the power light flashes orange. When I press the power button, it turns green but has no video or sound. It's done it before and...
the blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
May 06, 2010 | Hannspree HANNSnara 37 37 in. LCD...
I have a 37" Phillips LCD TV. it will not turn on and the light that used to show green (to signal the tv on) now blinks red. What does that mean?
how many times does it blink red. the will help determine whats wrong. Most lightly its going to give you 6 or 7 blinks whick points to the power supply this is sometimes a false indication to the ssb/signal board being bad. you coulb try the parts or have a tech come out and verify which is the problem.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Have a Magnavox 37 inch lcd hd tv When I turn the power on the green light flashes for about 10 minutes or so then goes solid. Once it is solid it turns off Turn it back on its solid again then off it goes...
sounds like the audio / digital board is going bad ---- they are about 130 refurbished and 300 new ----- look for one online before you pay an overpriced service tech who really doesnt know how to fix these tv's ----
I called the service support and they gave me three companies in Nevada --- each one of them had no idea what the codes meant, but would look at the TV for 225.00 - sounds like they need new companies to do their repairs on warranty
Feb 19, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Magnavox 27MS343S 27" TV Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
