Benq w1000 temp red, lamp orange
After starting beamer the temp symbol lights red and the the lamp symbol lights orange and the beamer shut down...
dhiman
  • 115 Answers
SOURCE: LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Posted on Nov 19, 2007
Marrie
  • 563 Answers
SOURCE: benq 8250 projector shuts down
Hi david115
I've had this problem MANY a time before and what BenQ does wrong is that they only replace the two main fans at the back of the PB8250 , they should in fact replace both the fans and the Mainboard. This is unfortunately the only way to get around this problem.
Posted on Dec 12, 2008
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Posted on Apr 10, 2009
projdoc
  • 2236 Answers
SOURCE: the projector doesn't turn on.power,temp,lamp orange light are on
overheated. clean it out with canned air. try again. if it still has an issue, you may have a main board problem.
Posted on Nov 12, 2009
projdoc
  • 2236 Answers
SOURCE: Projector powers down as soon as LAMP lights up
the ballast/power supply needs replacing.
Posted on Dec 23, 2009
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
My BenQ PE7700 stops working after a couple seconds.
the lamp is running too warm from inability to cool down. clean out the dust with canned air and check the fans. the temp sensor may need to be replaced, as the heat may have desroyed it.
Oct 14, 2009 | BenQ PE7700 Multimedia Projector
Benq pb8250 , red light blinking
you have a problem with either the fans, the ballast, or the colorwheel. if the fans turn on, listen for a high-pitched whir. if you don't hear it, replace the colorwheel. if you do, replace the ballast. if the fans don't spin, replace them.
Sep 22, 2009 | BenQ PB8250 Multimedia Projector
How do you open a BENQ MP610 projector to replace the light? What tool do you use? Thanks Marty
I just replaced my lamp for the same beamer. Took me a while to figure out how, but if you know how, it is easy. Turn the beamer on its back. In the middle, you will see a black rubber (small), it covers a hole and a screw is in the whole. Pull the small bblack rubber out. Unscrew the screw. A small cover will come loose. And there is the lamp, You have to pull out the power cable, and than only one little screw that mounts the lamp to the inside of the beamer.
It's easy!
Hope you will succeed,
Ojnoka
May 23, 2009 | BenQ MP610 Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
81 people viewed this question
k24674
