Question about Grindmaster Coffee Makers & Espresso Machines
The gfci trips when grindmaster coffee brewer plugged in
4 Suggested Answers
SOURCE: bunn coffee maker bt10-b is
The heating element inside is problably broken. Thats what mine does. just disconnect it and you will see that cures your problem. You cannot buy parts for this. I have tried already.Junk
Posted on Aug 27, 2008
  • 124 Answers
SOURCE: Bunn coffee brewer leaking
Is this a lot of water, or just a small amount.
As the unit sits over time and runs heating cycles, it may have some vapor come out of the vents. That will cool and collect around the unit.
try turning the unit off for the weekends. If you still have water around the unit, then it may have a leak in the tank.
Posted on Jan 03, 2010
  • 21 Answers
SOURCE: Trips Kitchen Breakers
Hello
It's the coffee maker.
John
Posted on Jan 07, 2010
My bunn water coning out is warm not hot
Make sure it's getting power, and that the "vacation" switch isn't on.
If on a GFCI outlet, press the RESET button - Do Not press the "test" button. If GFCI is located upstream on another outlet, or the breaker (not uncommon), try resetting the breaker or that other outlet.
If still no joy, check that the outlet is hot by plugging something else into it. If that item doesn't work either check the circuit breaker for that outlet by moving the lever all the way to the Off position, then back to the On position. You should hear a click like a light switch.
May 17, 2014 | Bunn 10 Cup Home Coffee Brewer
How can the length of the garden hose effect the amount of work done ?
Digital Satellite Coffee Brew Centers Model: BC302E-IT Twin
The Operator's Manual for your product can be found here:
http://www.grindmaster.com/docs/Ni90A-BC-IT-MAN.pdf
WATER HOOK UP
The National Sanitation Foundation (NSF) requires the following for NSF approved installation:
1. A quick disconnect water connection or enough extra coiled tubing (at least 2x the depth of the unit) so that the Brewer can be moved for cleaning underneath.
2. An approved flow-back prevention device such as a double check valve to be installed between Brewer and water supply.
WATER CONNECTION
The Brewer comes equipped with a ¼ inch compression water inlet fitting located in the back. Use a ¼ inch copper tubing to connect the Brewer to a cold water supply. Water pressure should be: 20 PSI min. to 90 PSI max. An external shut-off valve and a water filtering system with a charcoal filter are highly recommended. Turn water supply on and check for leaks at the water inlet connections, tighten compression fitting if necessary.
Hook-up using a garden hose would not be recommended; if the hose is too long you may not meet the minimum required pressure and will have difficulty filling the machine.
Feb 16, 2011 | Cecilware Coffee Brew Center wWater Tap...
Bunn ModleNHB
There is an electrical problem with your brewer. If you will locate the model and date code on the bottom of the brewer and then contact customer service, we will be able to assist you with resolving this problem.
Mar 30, 2010 | Bunn NHB Coffee Maker
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Trips GFI circuit brakers
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
Jul 30, 2009 | Breville ESP8XL Espresso Machine
Hello
John
Jul 18, 2009 | Keurig B100 Coffee Maker
BUNN Single Satellite commercial coffeemaker trips the GFCI
Sounds like the coffee maker has a leak which is causing a ground fault inside the appliance. A very minor leak (just water vapor even) can cause this -- one that would never show itself by running out on the counter.
I would suggest taking it apart and looking for evidence of a leak.
Apr 21, 2009 | Coffee Makers & Espresso Machines
Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Mar 31, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Coffee Makers & Espresso Machines Logo
20 people viewed this question
Top Grindmaster Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Grindmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
