Question about Braun 4745 Electric Shaver
My Braun 4745 Electric Shaver is not working. It "died" on me (slowly but surely) while I was using it. I have tried shaving while the shaver is plugged in and it then works for about 30 seconds bef
I can be e-mailed at mcohn@hotmail.co.uk
Ron_Ray
  • 13 Answers
SOURCE: Braun 5520 Shaver Stopped Working
The "Braun 5520" doesn't have the 2 screws under 2 small caps on bottom, as described by so many on these boards.
The round plastic plug receptacle 'itself' is the release. (Twist-Release the outer ring.)
Look on the base, where you plug the AC cord in.... Just inside the rim, you will see two small 'recesses', opposite each other, that allow a wedge tool (like a large screw driver) to turn the rim counter-clockwise (left) 45 degrees, releasing the base and housing.
Once this is unlocked, slide the cover off and pop the black retainer cover off to reveal the "PC Board W/Batteries" module/assembly. (Batteries are NOT replaceable by themselves.)
There is a tiny (and I mean "tiny"!) resistor that burns out in the circuit board and causes the majority of power malfunctions in these models.
You can order a new PC Board (with batteries) for approx. $40.00. (+ S&H)
One place is: "http://www.electricshaverstore.com/get_item_5505631_braun-pc-board-w-batteries.htm".
(Fits Models: 5510, 5515, 5520, 6515, 6520, 6510, 6512 - Types: 5505, 5506, 5705, 5706)
Or, find other by Googling "Braun 5520 Circuit board assembly", and/or replace this model with your number.
Posted on Mar 28, 2009
  • 10 Answers
SOURCE: I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Posted on Aug 29, 2009
brector3
  • 1624 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
brector3
  • 1624 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
  • 12 Answers
SOURCE: why does my clean and renew station leak all over
I figured out the problem for my Clean & Renew unit. Mine is 2 years old. About 3 months ago, I cleaned the buildup of whisker material from the TOP of the drain port [Left Side as you look at the unit] If you take out the cleaning solution cartridge and turn the unit upside down, you see the pump and the return ports. The return port is the smaller of the two. I found that there was a mass of dried whiskers in a few clumps clogging the return port. These clumps must have come loose and got caught within the drain port. I had noticed when I had the leaking problem I could hear bubbling just after the pump ran and the shaver turned off. I removed the clumps of whiskers and no more bubbling sounds and NO MORE LEAKS. My guess is that the fluid was draining back into the intake area and leaking on top of the cartridge. Hope this helps.
Posted on Dec 11, 2010
Tip
Huge list of SMTP server settings D-K
Provider - SMTP server
Datamat mail.datamat.it
Demon post.demon.co.uk
Digitel Italia smtp.etmail.it
Dinajpur www.dinajpur.biz
Dream Net Internet mail.dreamnet.co.nz
Earth Link smtpauth.earthlink.net
Easynet smtp.easynet.co.uk
eircom.net mail2.eircom.net
Elitel smtp.elitel.biz
Email.it smtp.email.it
Euronet NL smtp.euronet.nl
everybodycanadd itsverybad
Excite smtp.tiscali.it
EzySurf smtp.ezysurf.co.nz
FastMail mail.messagingengine.com
Fastweb smtp.fastweb.it
Fastweb mailbus.fastweb.it
fastweb pop.fastwebnet.it
Fastweb smtp.fastwebnet.it
fibertel.com.ar smtp.fibertel.com.ar
Free smtp.free.fr
Free Telecom smtp.free.fr
Freedom2surf outmail.f2s.com
Freemail smtp.freemail.it
freemail.it mail.freemail.it
freemail.it (supereva) mail.freemail.it
freenet mx.freenet.de
freenet.de mx.freenet.de
Freeserve smtp.freeserve.co.uk
Galactica.it smtp.galactica.it
Genie mail.genie.co.uk
GIGA smtp.giga.net.tw
Globe Net Communications smtp.globe.net.nz
gmail smtp.gmail.com
GMX mail.gmx.net
Go Daddy smtpout.secureserver.net
go.com smtp.go.com
Haier Electronics smtp.haier-electronics.com
Hinet msa.hinet.net
HiNet ms1.hinet.net
HOTMAIL (Please see Windows Live Homtail) hotmail.co.uk
hotmail (Please see Windows Live Homtail) mx2.hotmail.com
Hotmail.com (Please see Windows Live Homtail) mx2.hotmail.com
Hotmail.com (Please see Windows Live Homtail) mx1.hotmail.com
HotPOP.com smtp.hotpop.com
I4U Internet Services mail.i4u.net.nz
ic24 smtp.ic24.net
IG smtp.ig.com.br
IHUG smtp.ihug.co.nz
INET inet.it
Infinito mail.infinito.it
InfoStructure -- GRR Technology smtp.grrtech.com
InfoStructure -- InfoStructure smtp.mind.net
InfoStructure -- Klamath Falls Internet smtp.kfalls.net
InfoStructure -- Medford Internet smtp.medford.net
InsightBB mail.insightbb.com
Interbusiness (TI Easynet) mail1.cs.interbusiness.it
INTERFREE mail.interfree.it
Internet Zahav sout.zahav.net.il
internetlibero smtp.internetlibero.it
inWind mail.inwind.it
IOL mail.iol.it
Iomart smtp.domain.ext
IPrimus Australia smtp.iprimus.com.au
Iprolink smtp.iprolink.co.nz
istruzione.it istruzione.it
ItalyMAIL mail.italymail.biz
ixpres.com smtp.ixpres.com
jumpy mail.jumpy.it
Juno smtp.juno.com
Katamail smtp.katamail.com
Kataweb smtp.katamail.com
on Mar 24, 2010 | Symantec AntiSpam For SMTP 3.1
Dbmarshall1@hotmail.co.uk Facebook tell me my
make up a fake one and it always works for me
BE CARLFUL ON FAMOUS!!!
Aug 13, 2013 | Facebook Social Network
I want to go back to hot mail,i hate out look,..
On your Outlook home screen, click the GEAR in the upper right corner and select "Switch back to Hotmail
Feb 27, 2013 | hotmail.com
Cant access my email address @hotmail.co.uk
Contact hotmail/live, perhaps they have blocked your account due to spammer have hijacked your e-mail account. It's happened before.
Dec 20, 2012 | Dell Computers & Internet
I own a samsung GT I 9000. Have been trying to synchronize with my corporate mail server without success in spite of following the screen tips. Could you please help me or atleast guide me to a custormer...
Check the security settings of your mail server to ensure you're not being blocked.
Here are some 'standard' settings that may work with your system.
Gmail Incoming Outgoing
Access Type Web & POP3 Web & POP3
Email Address Format username@gmail.com username@gmail.com
Account Username Format
Full email address Full email address
Server Address pop.gmail.com
Use SSL: yes Port:995 smtp.gmail.com
Use SSL: yes Port:465
Hotmail Incoming Outgoing
Email Address Format username@hotmail.co.uk username@hotmail.co.uk
Server Address pop3.live.com smtp.live.com
ic24 Incoming Outgoing
Email Address Format username@ic24.net username@ic24.net
Server Address mail.totalise.co.uk smtp.tiscali.co.uk
UKGateway Incoming Outgoing
Email Address Format username@ukgateway.net username@ukgateway.net
Server Address pop.ukgateway.net smtp.ukgateway.net
UK Online Incoming Outgoing
Email Address Format username@ukonline.co.uk username@ukonline.co.uk
Username@ukonline.co.uk Username@ukonline.co.uk
Server Address pop3.ukonline.co.uk smtp.ukonline.co.uk
Vippowerent Incoming Outgoing
Email Address Format username@vppn.com username@vppn.com
Server Address pop.vppn.com
Virgin.net Incoming Outgoing
Email Address Format username@virgin.net username@virgin.net
Username Username
Server Address mail.virgin.net mail.virgin.net
Wanadoo Incoming Outgoing
Email Address Format username@ name.wanadoo.co.uk username@ name.wanadoo.co.uk
name.wanadoo.co.uk name.wanadoo.co.uk
Server Address pop.wanadoo.co.uk smtp.wanadooasdl.co.uk
World Online Incoming Outgoing
Email Address Format username@ worldonline.co.uk username@ worldonline.co.uk
Server Address pop.
tiscali.co.uk smtp.
tiscali.co.uk
Yahoo.co.uk Incoming Outgoing
Email Address Format username@yahoo.co.uk username@yahoo.co.uk
Username Username
Server Address pop.mail.yahoo.co.uk smtp.mail.yahoo.co.uk
Yahoo.com Incoming Outgoing
Email Address Format username@yahoo.com username@yahoo.com
Username Username
Server Address pop.mail.yahoo.com smtp.mail.yahoo.com
Settings - E-mail
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The following settings are if you use O2 Email as your ISP (Internet Service Provider).
If you require different settings eg Yahoo, Gmail etc please click here
1. Tap the Application tab on the bottom of the screen
2. Tap Email
3. Tap Next on the Welcome to Email setup screen
4. Tap on the Email address text box and enter your Email address then tap Done
5. Tap on the Password text box and enter your Password for your Email account then tap Done
6. Tap Next
7. Your phone will now try and download your setting to your phone and set up your account, if this can not be done you will see the message, Setup could not finish. Unable to open connection to server. Tap Edit details to continue.
8. Tap Manual setup
9. Tap the Username text box and enter your full Email address then tap Done
10. Tap POP3 account
11. Highlight POP3 server and tap the text box and enter mail.o2.co.uk
12. Check that Port is default set at 110
13. Highlight Next and tap
14. The phone will now check your settings
15. Tap the SMTP server text box and enter smtp.o2.co.uk
16. Highlight Next and tap
17. The phone will now check your settings
18. Tap Next on the Account options screen
19. You now have the options to add a name for your new account plus add your name to outgoing messages
20. Tap Done
Jan 02, 2011 | Samsung Computers & Internet
How to set up a hotmail.com e-mail address?
I can solve your problem, but a little bit intro of what's happening:
"Microsoft uses IP Geomapping to determine where in the world you are and then assigns you to your local e-mail address" means if your are in Uk you'll get to see only >@live.co.uk >hotmail.co.uk If u use proxy u'll get through.
So this link will redirect you to the US domain addressing @ Live/Hotmail.com
Dont forget to rate my answer :)
Feb 01, 2009 | Computers & Internet
Browse for http://get.live.com/mail/overview, it will redirect you to a page where you sign up for hotmail ID
Feb 01, 2009 | Microsoft Windows XP Home Edition
Braun 4745 Electric Shaver Logo
37 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
