Question about HP PhotoSmart C4385 All-in-One Printer
Printer won't print
I moved and unplugged my printer now it won't print. It will copy or scan but not print.
    Master:
  • 461 Answers
Check the connection to the computer. Something has happened to the cable or port or it is not inserted properly.
Posted on Jan 12, 2009
VOTIT
  • 2071 Answers
SOURCE: Won't scan or copy
Solution
These errors are usually caused by a failed scan, a bad installation, communication problems or software conflicts. Follow the steps below until the problem is corrected.
Step one: Restart the computer
Close all programs and restart the computer. A required task might have stopped running or the system resources might have decreased due to tasks left running. Restarting the computer will refresh all Windows tasks as well as increase the available system resources.
Step two: Check for the correct entries in the Device Manager
Verify that the unit was installed on a DOT4 virtual port in the Device Manager.
  1. Right-click My Computer , and then click Properties .
  2. Click the Device Manager tab. (In Windows 2000 and XP, click the Hardware tab , and then click Device Manager .)
Check the list of installed devices for references to DOT4. If there are no DOT4 references, the software has not installed correctly.
If any of these entries are missing, the software did not install properly. Review the information in the HP document Troubleshooting Installation Issues for USB-Connected HP All-in-One Products in Microsoft(R) Windows (bpu01858) for installation assistance.
Step three: Check for communication problems between the all-in-one and the computer
Communication might have failed between the all-in-one and the computer. Review the information in the HP document USB Connected HP All-in-One's Software Reports a Disconnected or an Error Status (bpu01859) to check for communications problems between the HP all-in-one and the computer.
Step four: Check the computer to see if it is infected with a computer virus
If the all-in-one prints but will not scan correctly and does not show any symptoms of communications problems, the computer might be infected with a virus. Some viruses try to disable virus scanning software and in doing so disable scanning from the all-in-one. The following are symptoms a virus problem:
  • The scanning software works after installing the all-in-one software until the first time the computer is restarted.
  • In the Device Manager, opening the Properties of the Imaging Device entry will reveal a status of "code 19" or "code 28".
  • A Scanner Cannot be initialized error occurs. While this error may other reasons, a virus will cause this error.
When the all-in-one is turned on and connected, follow the steps below to see if this is the problem:
  1. Right-click My Computer (click Start first in Windows XP) and then click Properties .
  2. Open the Device Manager:
    • Windows 98 and Me: Select the Device Manager tab.
    • Windows 2000 and XP: Select the Hardware tab, and then click Device Manager .
  3. Locate the Imaging Device entry and click the plus (+) beside it. It may have an exclamation mark beside it.
  4. Right-click the all-in-one entry under Imaging Devices, and then click Properties .
  5. A Properties screen will open. Look at the Device status section.
Hope it may helps;.
Regards, VOTIT
Posted on Sep 20, 2008
SOURCE: Printer will copy and scan but will not print anything from internet
copi driver instal to my computer
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: Dell 962 Printer won't scan
re-install the software that came with the printer.  that should solve the problem
Randy
Posted on Dec 02, 2008
diddydaveh
  • 154 Answers
SOURCE: I can't scan on my Brother MFC 5440 CN
Hi, remove the softsware that came with the Brother, and then re-install as per the manufacturers instructions
Posted on Jan 10, 2009
SOURCE: HP 6210 won't scan or copy (prints okay)
Same problem here too! Ever resolved?
Posted on Jun 25, 2010
Doesn't want to copy
Are only copies affected, does it print well?
Nov 07, 2013 | HP Photosmart 3210 Printer
Hp 380 allinone won't print or copy but will print something i scanned in
it is better dont purchase HP series.. its all waste... they are simply selleing by advt. No customer service. Useless....
Dec 14, 2011 | HP DeskJet F380 All-In-One Printer
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Brother DCP 1200 printer/copier...won't copy/print
The scan lock is the switch on the left side of the printer above the fan outlet. You flip the switch to lock it before moving the printer. Flip the switch to unlock the printer
Mar 05, 2009 | Brother DCP-1200 Laser Printer
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Can't get the printer to print
Cycle power including unplugging AC cord from printer.
If you cannot copy (scan) after power on, the printer is bad.
You should be able to copy (scan) after printer is turned on and initializes (It will say "COPY / 100%").
Feb 18, 2008 | HP PSC 2110 Color Printer
Lexmark aio will not scan does everything else!
all these problems seem to be with Lexmark equipment
Dont see any Epson problems, story here somewhere
Feb 14, 2008 | Lexmark X1270 All-In-One InkJet Printer
HP PhotoSmart C4385 All-in-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
