Question about Watches
How to turn off chime on timex w212 143-0950004
We have set the time and date. Now we need to know how to turn on and off the alarm (and chimes).
SOURCE: dont know how to turn on hourly chime timex atlantis 100
Set chime and Alarm on or off
Press MODE to select ALARM
Press START/SPLIT to change (clock sign and chime sign will appear and disappear as you keep on pressing).
Press MODE again and you are all set.
Posted on Jan 05, 2009
SOURCE: i want to know how
I have a Timex Men's Classic Digital Silver-Tone Expansion Band Watch #T78587. To turn the chime on and off on this watch, I press the Start/Stop button on the top right once. This toggles the chime on and off. If you hear a single beep then you have turned it on. If you hear no beep you have turned it off. You can tell the chime setting by looking at the colon seperator between the hours and minutes. If it is flashing then the chime is on and if it is not flashing then the chime is off. This is not explained in my watch manual nor in any of the manuals I downloaded from Timex.com.
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
Posted on Jun 12, 2009
SOURCE: Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Posted on Sep 27, 2009
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
How do I turn off chime?
Hi mfchester,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Apr 19, 2011 | Timex 1440 Nylon watch
How do I set the time and date on my timex 1440 sports watch?
Hi rtjjall,
Hope it helps.
Mar 21, 2011 | Timex 1440 Nylon watch
I do not know how to set the alarm
Hi benchilcott,
Hope it helps.
Dec 01, 2010 | Timex 1440 Nylon watch
I have A 1440 sports watch. I cant get the chime or alarm to sound off.
Hi Guest,
Hope it helps.
Jul 13, 2010 | Timex 1440 Nylon watch
Hi i forgot how to set the time on my timex 1440 sports watch
Hope it helps.
May 20, 2010 | Timex 1440 Nylon watch
Timex 1440 sports watch. How do you turn off the chime on the hour every hour?
Hi aburns983,
You can easily change the time and turn off the chime of your Timex watch by following the steps below.
Hope it helps.
Nov 05, 2009 | Timex 1440 Nylon watch
Aug 30, 2009 | Timex 1440 Nylon watch
Dont know how to turn on hourly chime timex atlantis 100
Dec 28, 2008 | Timex Atlantis 100 77517 Wrist Watch
WR30 Wristwatch
hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
1 time takes of the chime-hourly beep
2 times takes off the alarm tha you set
3x's puts the chime back and 4x's puts the alarm back on.
Jul 21, 2008 | Timex 1440 53591 Sports Quotient...
Watches Logo
235 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
