Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
When running washer we are hearing loud noise fm water pump motor, and see error Sud, soon followed by F02. Have checked at filter by unscrewing white cap at front of washer after removing bottom cover, found no debris. or anything in drain boot.water appears to drain and washer spins on Drain/Spin, after plugging washer back in. regular wash failed again withF02 and water pump motor making noise as before. If this needs replaced, it appears we cannot just get electric motor, but must get whole water pump assy. Correct? This washer was purchased in 2002. and assume that it is ghw9100lw0
  • 1 more comment
  • penver88 Jan 12, 2009
    I have the same problem do i have to replace the water pump to fix it
  • housewife101 Jan 19, 2009
    HI,
    I am having exactly the same problem with my machine. I would appreciate it if any body has any
    answer or solution other than buy a whole new pump.
  • kmarshallrea Apr 11, 2009
    I too, have the same problem. For the money of this washer/dryer pair, the performance and maintaince costs have been very disappointing!
  • 640 Answers
If your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Posted on Jan 12, 2009
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool front loader say f02
If I am not mistaken f02 code means that long drain. put into spin and see if the pump turns on if it does check if water is coming out... if not need to check if there is something stuck in the pump blocking the flow for the water
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
Potential Causes
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin out water, shows F02, already checked the hose for kinks and/or clogs?
Potential Causes
I recieve a 02 F code on my Duet front loader
02 means = Long Drain
Solution -
  • If the above does not correct the problem, replace the pump.
Jul 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting the f 02 error on my whirlpool duet front loader. The hose is clear and I can here the pump running. I need to clean out the pump filter but don't know where it is.
Potential Causes
Jun 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
Washer does spin out
"F02" is a Long Drain error code. It sounds like your drain pump has failed and is not draining properly. This is probably also the cause of the "SUD" error and the noise you're hearing. If you wish to replace the pump, I recommend replacing the entire unit. Searspartsdirect.com carries the part for about $71.00. Just type in your COMPLETE model number in the Search menu and look under the "Pump and Motor Parts" heading for item #10. If you look under my profile under "Tips and Tricks" there is a posting on how to replace a drain pump on a front loader. If you can't the information you're looking for, or need further assistance, let me know. I hope helps you.
Apr 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
607 people viewed this question
Dan Webster
Dan Webster
Sal De
