Question about Lexmark X6150 All-In-One InkJet Printer
Alignment problem how do I know if it is the driver?
  • 5saldys Jan 14, 2009
    Fix Ya did not give me back my money lilke their guarantee says. I was not satisfied and let them know and nothing.
  • 818 Answers
  • Sergio Scalfaro
    Sergio Scalfaro Jan 14, 2009
    sorry for the happend, please do you have put refill cartrige or original?
    Sergio
99 Lincoln Town Car I replaced the drivers door and the left fender The door does close there is a large gap between the left rear door and the drivers door please help me with the right alignment
There is no magic way to make all this sheet metal fit correctly other than trial and error and a lot of shimming of parts to correct alignment, that is why body shops charge so much for their services Sorry but have tons of experience in this type of work so absolutely know what is what here. I know it is a pain in the rear, but keep at it, you can get the parts to fit right with a lot of patience and hard work.
Nov 22, 2016 | Lincoln Town Car Cars & Trucks
Uneven tire wear and struts problem
Sounds like you should have the alignment checked on an alignment machine on all 4 wheels.Once you get those readings and an expert alignment mechanic's estimate on repair,only then will you know the correct repairs needed.
Apr 28, 2017 | 2004 Honda Accord
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Alignment Issue
Browse through the menu, there must be a head alignment test/function. Also inspect the printer driver and/or utilities installed on your computer and find a head alignment function.
It's not complicated, either it's fully automatic, or you'll have to look at a printout and choose the best-aligned lines, depending on printer model.
Nov 01, 2009 | Lexmark X7350 All-In-One InkJet Printer
2000 Impala drivers side window not aligned
You took window out???you need to take door panel off and align the window regulator, if thats what you took off. if you didnt touch anything in the door, then the regulator may have a problem.
Oct 12, 2009 | 2001 Chevrolet Impala
I have printer x2500, when the unit is power on, the ink device goes from left to right hitting both end and stay in the extreme right side, and do nothing. There is any alignment procedure??
Hi
Usually the alignment process executes when the ink cartridges are changed or replaced .
There is a way to print the alignment using the printer drivers in the printers and faxes folder.
let me know if you need further assistance
Jul 14, 2009 | Lexmark X2500 All-In-One Printer
Driver front wheel popping on 2007 chevy reg. cab silverado
i would do i front end alignment because when you drop your truck it gets out of align.
Apr 02, 2009 | 2007 Chevrolet Silverado 2500HD
Stuck in a queue for align cartridges.
>Remove cartridges
>turn off machine
>uplug machine and disengage from pc
wait 20 minutes
>do everything in reverse order(put everything back
This is a simple reset. Is the machine now working?
If this is not working, look very carefully inside the printer sockets- are there any bent wires ? any broken? is there dried ink globs anywhere?
If everything looks okay, then we next need to check to see if your printer driver is up to date or has become corrupted in some way.
go to this site
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Enter you info and download the appropriate driver for your printer and your operating system.(Make sure you get the correct driver) Be sure to turn off all running programs when you do this including your firewall. Download it and save it to your desktop. It will be an exe. file on your desktop. Before you install it, turn the printer off. Click on the icon to install the new driver. Then turn the printer on and see if all is well. Good luck and if this does not work, let me know. I have had many HP printers.
Good Luck to you!
Aug 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer wont align
Can you complete the alignment through the maintenance tab on the driver via your computer?
Jul 26, 2007 | HP PSC 2410 All-In-One InkJet Printer
Lexmark X6150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
