Question about KitchenAid Refrigerators
I have a Kitchaid built in side by side model # KSSS42QJX00. Freezer is blowing cool air not cold air and food is thawing. What are the possible causes?
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
Posted on May 10, 2008
kram26
  • 544 Answers
SOURCE: My Kenmore fridge, Model 596-58692890
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 24, 2009
whytfang
  • 170 Answers
SOURCE: KitchenAid Side-by-side (ksrg25fkwh05) - Freezer not working
The odds are it is a circuit board problem...I had a huge Amana 27 cubic foot side by side and it did the same thing...I diagnosed the problem and replaced the circuit board ....which actually controls everything...one sure sign is to pull the unit out as the other person did and to access the back of the unit where the compressor is...(the comptressor should be on 85% of the tme....if it is not on and warm or hot to the touch then it is a circuit board problem....since compressors will continue to run if there is a defrost problem (most of them anyway), or an Ice build up, etc etc. I don't recommend a layperson trying to replace the circuit board (mine cost $115,) but if you do it is generally in the door mine was a long thin circuit board behind the fridge door handle. .P.S. the heat that the other person felt on the door and around the door seals is normal lots of people don't even know this heat strips exist until something haappens and they start feeling around...these heat strips are to prevent frost of ice build up where the door meets the fridge framd...which can happen due to the extreme temp difference between the two...(inside temp and outside temp).
I hope this has helped...good luck...Knowledge gives you a base from which to yield power over unscrupulous repairmen whop may try to take advantage of people.
Again ...good luck and let me know what happens.....Please rate me .....The Fang.
Posted on Mar 27, 2009
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
  • 531 Answers
SOURCE: I have a GE Profile side by side and it is not
you may have defrost problem
Posted on Apr 06, 2009
My ge refrigerator model pss26sgpa is not cooling in fridge or freezer
make sure the condensor fans are clean they are prob. full of dust. bottom rear of unit.
Apr 18, 2012 | GE PSS25NGM Side by Side Refrigerator
My kenmore refrigerator model # 363.9771611 runs but is not cooling and the freezer is not freezing
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food.
You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Other Causes
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Have a good day! : )
May 04, 2011 | Kenmore Refrigerators
Hotpoint side by side refrigerator. Freezer stopped blowing cold air while refrigerator side continued to cool. Freezer was totally thawed when I discovered problem but refrigerator side was still...
Hi
Check the freezer to ensure it isn't over loaded with food stuff; reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. Also check whether the unit needs defrosting or not. You should also check the coils on the rear of the refrigerator and make sure they are clean and dust free. If you still have problems after trying the above; you may need to call a repair service to come out and check the unit
Please check the bellow links to have a detailed idea related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
http://www.applianceaid.com/frig_notcold.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Hotpoint Refrigerators
Maytag bottom freezer Model MBF2254HEB not blowing cold air into freezer or fridge, blows warm air if blowing at all, starts and stops. Any suggestions? Possibly a reset button somewhere? Thanks - Kurt
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Refrigerators
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refridgerator is cool, but not cold.....of course the same for the freezer. the freezer is running, just nor getting cold enough. food is thawing and thermostat is reading almost 40 degress in both...
Je your defrost thermostat, heaters or timer is not working correctly or at all. The freezer has the coils that freeze the freezer and cools your fresh food area. When your defrost does not work these coils become blocked with ice and will not let air from fans pass through!!! Leaving a moderate temp in fresh food area.
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side whirlpool refridgerator GD5SHA is no longer cooling
Your refrigerator has an Adaptive defrost board inside the fresh food compartment that is the number one reason I think your refrigerator is not cooling. Reading your post you mentioned this just suddenly began to happen. Can you hear the compressor running? Is your fans blowing inside the freezer and below the refrigerator? Can you feel warm air coming from back and under refrigerator or cold air blowing inside freezer? Click on link below and enter your model in search feature. You will see 36 similar choices, just make sure you choose one that has refrigerator beside the model number. When you get to the correct page choose photo 10 control parts click it and you will see the Adaptive defrost listed in photo as item 6. Let me know those other things I asked in this message so I will be able to help you better, Thanks Sea Breeze
click be low link enter model GD5SHAXLB01 in search feature
http://servicepartstec.blogspot.com/
May 20, 2009 | Whirlpool GD5SHAX Side by Side...
Freezer side cold, food side warm not working
3 possible problems.... Machine is possibly not defrosting (if this is it, eventually the freezer will not work as well) The damper between the two sides is possibly not operating, or the fan on the freezer side is possibly not blowing the cold air into the fresh food side.
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have side by side refrigerator (approx. 10 yrs old). Fridge no longer keeps food cold enough even at highest setting and freezer isn't as cold either.
Your refrigerator needs to be turned off and aompletely defrosted. Overnight if possible. You have a large amount of ice built up on the freezer coil that is blocking air flow.
Most refrigerator sections are only cooled by air flow from the fan in the freezer section.
Thaw it and clean it out real good and you should be back in business.
Jun 10, 2008 | GE Refrigerators
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
56 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
