SOURCE: whirlpool side by side fridge freezer s20-d rbb32 a/g
Either there is a loose connection at that board or in the plug where the wiring goes into the door (should be at top or bottom door hinge). If all connections are tight then replace the board. Not sure how old this unit is but it does come with a one yr warranty from date of purchase.
SOURCE: Whirlpool side-by-side fridge/freezer continuous operation
have you cleaned the coils under the unit remove the toe kick in front and use a shop vac
SOURCE: Flickering display panel on Whirlpool
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
SOURCE: Whirlpool S21S4d - How do i use the ice maker function?
http://shared.whirlpoolcorp.com/product_literature/search.jsp
If you have more model info. try this link.
SOURCE: Whirlpool S21S4D Ice maker stopped working
You have a defrost problem going on. Either the defrost timer, the defrost t-stat or the defrost heater. Remove the back freezer wall and you will see the evaporator coils. This is where the heater and t-stat are located. One of these is more than likely the problem.
Testimonial: "We have just looked at the recommendation and it looks like the heater is not working properly! Will source the part tomorrow. Well done Fix Ya"
