Question about Durabrand DU1301 TV
How do I delete a channel?
My cable company says I have to delete it manually. I can't do that. It automatically selects for me. How do I delete the channel. It gives me an option to add/delete but I can't do it.
    Problem Solver:
  • 7 Answers
The easy way for most of the TV's to delete a channel is to go into Menu on your remote and go to Add/Delete channels. Once you are in this screen you should have an option to delete a channel. Press that and type the channel number to be deleted. It should work. Good luck.
Posted on Jun 09, 2007
2 Suggested Answers
bluenadas
  • 203 Answers
SOURCE: deleting a channel
Orion builds that unit and I can not find an owners manual online for it anywhere. If you want, you can buy on here: http://www.orionsalesinc.com/miva/merchant.mvc?Screen=CTGY&Store_Code=OSI&Category_Code=DU1301 It should tell you in there how to go about deleting and adding channels.
Posted on Jun 12, 2007
Insignia tv channel scan duplicate channels
the set should have in the menu a way to manually add or delete channels, consult the owner manual and or look for that feature in the sets menu.
Apr 16, 2012 | Insignia 42" LCD Flat-Panel HDTV
Deleting a channel
Jun 09, 2007 | Durabrand DU1301 TV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
I need to change the channel settings on my RCA DCM425 cable modem. The problem is my company set up the router and wireless along with an ASA and I do not have any of the original information. How do I...
Cable Modem Troubleshooting RCA DCM425
or
You can change the radio channel on your AirPort Extreme using the AirPort Utility, as follows:
  • Run the AirPort Utility.
  • Select the AirPort Extreme, and then, select Edit.
  • Select the Wireless tab.
  • Select Wireless Options.
  • By default, the channels for both the 2.4 & 5 GHz radios are set to "Automatic." You would first change this to "Manual," and then, select the desired channel.
Oct 10, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My remote no longer works and I can't get the menu to come up so that I can reprogram my channels and get all of my cable channels. Right now I only get basic cable channels, even though I have full...
You will have to disconnect the TV from the AC outlet for a few seconds(10-20) then reconnect the TV and press power. You should get the start up menu after you get a picture. What you have to do is use the vol up/dn , chnl up/dn keys to select the autoprogram setting after chosing from cable or antenna signal. the enter key should be one of the DVD keys either play or stop or some other key, you'll have to experiment a little with it. There is an owners manual available at retrevo.com in case you need it, but I am posting a brief description stated in the manual on how to do this. Chapter Summary: The STARTING SETUP function makes installing your TV/DVD easily...It leads you the Language selection, TV/CABLE selection and auto channel memory automatically...... Make sure that the antenna or cable TV system connection is made... ENTER CANCEL... Starting setup... Press POWER...The starting setup function begins and the Language setup menu appears on the screen...Press or to select your desired language, then press ENTER...... Users also looked at: Press or to select the “AUTO CH MEMORY”, then press...... 5S10101A [E] (P13-23) 23... This TV/DVD is equipped with a channel memory feature which allows channels to skip up or down to the next channel set into memory, skipping over unwanted channels...In addition to normal VHF and UHF channels, this TV/ DVD can receive up to 113 Cable TV channels...When shipped from the factory, this selection is in the CABLE position...... Press or to select “TV” or “CABLE...... Press MENU in the TV mode, then press to select option...... Cable TV chart... Press or to select “ADD” or “DELETE”, whichever function you want to perform...... The chart below is typical of many cable system channel allocations...... Press or to select “TV/CABLE...... Press press... TV/CABLE selection Automatic memory tuning... TV/CABLE AUTO CH MEMORY ADD/ DELETE... or... to select “ADD/DELETE”, then...
May 19, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Audio cuts out on my reciever
Try selecting any option for decoding priority from "auto" to "pcm."
May 09, 2009 | Audio Players & Recorders
I have an older Magnavox tv-vcr 13"combo, model MC132DMG01, I selected auto-programming to set the channels, now I can't get the channels I used to get, and I don't know how to override the automatic...
Auto-programming cannot select channels it can't detect. You may have to select manual programming and step through and set each channel manually.
Dec 30, 2017 | Televison & Video
Durabrand DU1301 TV Logo
363 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
