Question about Kenmore 74902 Gas Dryer
Kenmore gas dryer that turns but does not heat up
My Kenmore gas dryer turns but ther's no heat, what's the problem and how do i fix it? Dryer barely warms. Is there a schematic that will show where the fuse is?
  • 640 Answers
Mostly you need a thermal fuse,,take the back of ,,maybe 12 1/4 nut driver screws,,you will see a little white fuse,,replace it..onthejob
Posted on Jan 12, 2009
My Kenmore series 90 Gas dryer doesn't heat up.
This dryer is what I like to call a 4 wheel drive model. Because it has wheels on the front as well as the back. To access the gas assembly you pop open the bottom panel. Strat the dryer and observe the gas assembly. You should hear a click and then the ignitor should glow. Next the flame sensor should trip and cause the ignitor to shut down. The gas will now be allowed to come out and fire off a blast.I have 2 home videos. on shows the operation and replacement of the coils. The other is of an electric model but shows how to put the dryer together.
Sep 21, 2012 | Kenmore 73052 Gas Dryer
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Kenmore Dryers
Kenmore 90 Series dryer will not heat up.
heatman101
Aug 02, 2011 | Kenmore Dryers
My dryer is barely getting warm so it doesnt dry very well.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | Kenmore Elite 20972
Thers not heating on my dryer motor is runnning but no heat
heatman101
Jun 26, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Kenmore D433ele will not turn off...will not heat
heatman101
Jul 31, 2009 | Kenmore 400 6942 Dryer
No heat at all? does the top of the machine heat up, but not the drum? could be your drum seal is damaged or slipped off.
If the firebox doesn't light up, could be your igniter, the unit's safety switch, thermocouple, or regulator; Your Gas Company may provide a service that would check it for you... some do.
Jan 02, 2009 | Kenmore 74602 Gas Dryer
I NEED OWNERS MANUAL TO KENMORE DRYER
thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Mar 27, 2008 | Kenmore 63942 Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 74902 Gas Dryer Logo
171 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
