Question about Garden
My Wickes pressure washer won't switch on. It's just dead. Checked fuse.No water blockage.
4 Suggested Answers
  • 384 Answers
SOURCE: Pressure washer will not start
Clean out the Nozzle with a small diameter wire.
Posted on Sep 15, 2009
  • 36 Answers
SOURCE: Pressure washer won't start.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Posted on Aug 22, 2011
spraydoctor
  • 97 Answers
SOURCE: K5.140 low pressure and motor pulsates when trigger released
Trevor,
The pulsating of the motor that you observe is occurring because the unloader valve is "cycling", over and over and over. This happens when the unloader can not trap the pressure down-line from it. Whether you have an external leak or not, your unloader is leaking internally.
On home-owner class pressure washers, the unloader valve is not a completely separate part -- as they are on commercial pressure washers. Rather, the "body" of this part is molded right into the "manifold head" of the pump. So if you are looking at the pump, the unloader is where the pressure hose hooks up (The hose is not really hooking up to the pump, but is hooking up to the outlet of the unloader valve).
What you need is an "unloader rebuild kit". To get this, if I were you, I'd find a Karcher dealer, who will look it up making any necessary cross-references etc. and come up with a part number for the kit. This kit will contain all the wearable pieces that go inside the unloader.
Also inquire with said Karcher dealer about an exploded representation of the unloader so you can see where everything goes (and how it comes apart and goes together). If such a dealer tells you he/she has no such thing -- that is likely not true. It is, however, true that these dealers may feel justified in not wanting to be "tasked" too much because they earn very little $margin$ on the sell of these parts. At any rate, you need this parts explosion and if a dealer is not willing to get you hooked up with it, go somewhere else! Also, these service sheets may be available online, but I have not been able to locate them (admittedly, my search has been cursory).
When you do this, be sure to wash out every little piece -- because we know there is damage and bits a pieces of the old wearables may be inside cavities and this could/would cause things to not work upon completion. Do this work in a well lit area and be sure your vision is as good as it can be. I generally wear reading (magnifying) glasses to be certain I can see all detail.
Good luck and if this is helpful to you I hope you'll take a sec to rate me. Thanks!
Don
Posted on Mar 17, 2012
Testimonial: "A very full and technical solution. I have requested advice from a repair centre today and they are checking machine on Monday with a view to advising if it is financially worth repairing the unit. I will keep posted as to result."
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Pressure washer won't deliver pressurized water.
sounds like you have a blockage maybe in your water hose ,ideally your water hose should be around 25 feet..or you may have an o ring in the gun where the tip goes.. is broken..that will affect your pressure..check also filter where water hose connects to the pump make sure thats clear
Sep 30, 2017 | Briggs & Stratton Briggs Stratton 1800...
My marcher m520 electric water blaster stopped working as if it has blown a fuse but when I remove the cover I cannot see any sign of a fuse. Do they have one and if so where is it located. Thanks Pete
is there i ground fault switch at the power cord plug . if there is reset it . another problem with electric pressure washers is if water can't pass through wnd and nozzle they won't operate. there ian't a fuse inside unit.
Sep 24, 2011 | Alfred Karcher K 5.93 M Electric Pressure...
No fault code washer will not fill
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool WTW6400SW Cabrio Washer
My washer wont fill with water what seems to be the problem
Hi
Daniel
Aug 10, 2011 | Samsung WF210AN Washer
Water not entering washer
Hi
Daniel
Aug 03, 2011 | Maytag Bravos MTW6600T Top Load Washer
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
