Question about SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter
How do I insert the adapter into my laptop? The adapter is too small for the slot where a normal memory card would go.
  • Anonymous Apr 08, 2009
    i have had the problems and it got stuck into the port when i pushed it in to far and now i have a sd card in my laptop anyways, you gave to buy an adapter for it really, those thing do my head in
    Problem Solver:
  • 8 Answers
Don't know the size of the micro with its adapter, but if it is the size of a duo card you should be able to put your micro with adapter into a Pro adapter and this is the memory stick that most card readers accept. Sony has been pretty much backward compatible so I feel this should work. A Pro adapter runs about $10 @ Best Buy.
Posted on Aug 01, 2009
Driver for Memory Stick Micro (M2)
Never heard of memory sticks needing software!
Sep 28, 2012 | SanDisk 2GB Memory Stick Micro M2 Memory...
When i remove memory card and insert or switch on and off my cell phone all the data in memory card is losting. please give me some suggetion.
Firstly switch off your mobile.Then put out your memory card adapter from your mobile.then re-enter the memory card adapter in your mobile, but sure of that if your small lock in your adapter is unlocked.It is unlocked by hand.Then ENJOY.
Jan 02, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
Unable to read my memory card, it seem to be memory slot problem
i need to open my SanDisk M2 memory card, but my card reader is unable to read it. please help. there are important files on this memory card. thanks in advance..
Oct 19, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    How to insert sandisk memory stick micro 1gb to computer?
    Yes, you will need an adapter unless you have a card reader that accepts that specific type of card.
    Dec 05, 2009 | SanDisk 1GB Memory Stick M2 Memory Card
    The SD m2 2gb Micro does not work on my phone
    the card shows sign of a rom ic being lost its firmware
    Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    My phone is not detecting the memory stick micro
    Format the memory card in pc or any other phone then insert in your phone it will work.
    Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    M2 memory card needs formated
    insert into your computer, Go to my computer and right click on your memory card. go down to format.
    Jan 21, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    Micro M2 memory card adapter
    Memory stick flash memory is tricky. If it is too small, DO NOT INSERT IT. I made this mistake and was lucky enough to have some tools handy to get it back out. You'll need a different adapter to use it in the memory card reader that you have.
    As for "guest" 's conundrum. You will need to use either needle nose pliers or tweezers to VERY CAREFULLY remove it. It won't be easy and you have to be careful so as not to push it farther in (which eventually it will stop going in, but still makes it that much harder to get it out)
    Good luck
    Jan 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    The m2 adapter i have does not fit my acer aspire laptop yet my laptop card reader says it reads m2 memory cards. is there a certain way of putting the card in to the memory card reader.
    I think that with smaller memory cards like m2 and t-flash(micro SD) you would have to use their adapter(a card with a slot that normally converts it to SD) before you can slot it in.
    Nov 06, 2008 | Computers & Internet
    SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter Logo
    311 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
