Question about Sylvania 6626LCT 26 in. LCD Television
Keeps turning off
Every 5 min it turns off
  • 3 more comments
  • Buffy99 Dec 05, 2007
    My 42" Visio Plasma TV keeps turning off. It happened about a month ago, then it did it twice this morning about 5 minutes apart.
  • madmatt5170 May 11, 2008
    My sylvania flat screen turns off within 20- 30 seconds after I turn it on
  • Anonymous Jan 23, 2009
    i have the same problem except its with a samsung plasma
  • davidpenasr Jan 27, 2009
    My Sylvania Model 6626lct will produce only sound, no picture, and then it will completely turn off. It is only 16 mos. since purchase. Anyone have the same problem, solution?
  • latinstarmex Feb 25, 2009
    My tv (RCA) keeps on turning on and off every 9 seconds
  • 101 Answers
As for the 10-20 secs ,tv turns off .......I have one of those ......Im still trying to fix mine, without buying a new board ,I will post results!
Posted on Sep 11, 2009
  • squidsr62 Dec 29, 2010
    What was your solution to the problem?
    President:
  • 1,755 Answers
Hi, Is it posible that you have turned the sleep timer on. On most TVs there is a sleep timer. Also check that clock .
Posted on Oct 07, 2011
  • Juan Mosquera
    Juan Mosquera Jan 19, 2016
    The timer is off and it actually turns off in less than HAPPY 5 minutes.
  • Joseph Hoffmann Jan 20, 2016
    It could well be the main board. (bad capacitors) You will need a tech guy to confirm. (repair man). If repair cost is more than a new TV then go buy a new TV.
  • 23 Answers
Test with a watch. If it is exactly at 5 minutes, the above is correct, otherwise you have another issue
Posted on Aug 29, 2007
It sounds as though your Energy Savings option is turned on. You may want to find this option and either turn it off or change the time to turn off like two or three hours later.
Posted on Jun 12, 2007
Why does it keep shutting down after 5 min of playing a game?
Xbox Keeps Turning Off - Xbox 360 S - iFixit
https://www.ifixit.com/Answers/View/.../Xbox+Keeps+Turning+Off
iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Does Your Xbox 360 Keep Freezing? ' MyGamerXP
www.mygamerxp.com/xbox/does-your-xbox-360-keep-freezing/
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
My 250GB Slim keeps turning itself off every 5 - 10 minutes ...
forums.xbox.com/xbox_support/f/7/t/156970.aspx
Xbox
Jan 17, 2016 | Video Game Consoles & Games
Touch screen not working
is it just the touch that stops working? or all off the computer?
May 22, 2014 | Toshiba Satellite Computers & Internet
Car will not start
Try this... turn the key on (just before the start position) for 10 min then
off for 5 SECONDS then back on for 10 mins then off for 5 seconds then on for 10 mins then off for 5 secs. I just went thru this with my daughters car. By doing this you reset the computer (and the alarm). If this does not work then I'm sorry.
Aug 30, 2012 | 2002 Chevrolet Malibu
2007 Pontiac G6 GT radiator fan keeps running after engine is turned off. Runs for another 4-5 mins after engine is turned off.
Heat sensor keeps blowing air thru radiator until it cools, then cuts off. Some auto do this. If it bothers you let the engine idle a few min. after you drive it and then turn car off. When you drive your car and the engine is hot it heats up even more when you turn it off because the water has quit circulating. The fan will run til it cools. It's supposed to do that.
Sep 03, 2010 | Pontiac G6 Cars & Trucks
Settings wont change
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
IF both remotes are dead will this cause the theft system to keep car from starting?
no it wont. now what you do is turn the key to the on position. do not attempt to start, just leave it in the on position for 10 mins. it must be 10 mins to reset theft sytem, turn key off wait 5 sec and turn back on make sure theft light goes away and start
Jun 28, 2009 | 2001 Chevrolet Monte Carlo
D LINK DI 604 KEEPS KICKING ME OFF
are any lights going off or flashing on mdm ? then call isp . . when was the last time you pwr cyc mdm AND router if it has been awhile try that turn both off for for 3 to 5 min turn mdm on first wait for dsl light wait 2 min turn router on wait 2 min try again if still have problems connect direct to mdm and if still doing it it isn't the router it is the internet connection or mdm
Apr 07, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Sylvania 6626LCT 26 in. LCD Television Logo
764 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
