Question about Zanussi ZWF1440 Front Load Washer
Zanussi zwf1421w 4 beeps
Washer will not work and beeps 4 times
5 Suggested Answers
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
  • 26 Answers
SOURCE: ZWF1421W Zanussi Wasing Machine
Unscrew filter body and gently, using a pair of mole grips, wiggle and pull the filter body.
If this doesnt work the best option is to replace the whole filter assembly. You do not need a new pump though!!.
PS Cleaning the filter on a regular basis will help prevent this!!!!!
Posted on Nov 19, 2008
  • 3741 Answers
SOURCE: Zanussi zwf1421w washing machine makes a
Motor is kicking on and off making that noise....so far for us this has been a motor issue 9.5 times out of 10
CLICK THE LINK DIRECTLY.http://www.youtube.com/watch?v=EqeGv3B-3xw
Posted on May 05, 2009
apart4u
  • 213 Answers
SOURCE: How to replace DOOR SEAl for zanussi zwf1421w
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
I have a zanussi zwf1421w its not spining out the clothes properly. Yet its not vibrating badly to indicate its off balance. Also not always draining the water away and I have noticed the lights on the...
Assuming your pump is now ok could be the motor or brushes more to the point that is making it not spin too well. Brushes on this will last about 5 years after that well worn......
Apr 06, 2010 | Zanussi ZWF1420W Front Load Washer
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
My Zanussi ZWF1421W has stopped taking the fabric conditioner through in the wash cycle - it remains in the drawer....
Zanussi ZWF1421W
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 30, 2009 | Washing Machines
Zanussi zwf1421w washing machine makes a rumbling/rattling noise when spinning.
May 05, 2009 | Zanussi ZWF1420W Front Load Washer
Wahing machine
Try pushing the skip button this may reset the prog. These machines will beep to indicate a fault. Dependant on how many times the machine beeps b4 it pauses ie 1 beep then a pause would indicate the machine isn't filling, 2 beeps its not pumping out, 4 beeps doors open. Hope this helps
Nov 30, 2008 | Zanussi FJS1225W Front Load Washer
Nov 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi Washing Machine
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
47 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
