Question about Pc America Restaurant Pro Express
What is the process for running individual reports for each srvr?
My quick start guide is rediculous-Worthless!! How do I run each seperate girls report that shows Sales ( Cash, Credit C.) breakdown etc. The reporting screen has lots of options but none that look like anything I need for this report. And is there a more advanced guide I can purchase with SOME DETAIL to it? HELP!!!
There are a variety of reports that you can print based upon criteria. Just run reports based upon the cashier (girl). EX Detailed Department Sales Criteria: Cashier 1.
Or call there tech support team!
Hope this helps!
Posted on Jan 23, 2009
Memory is used up by excel
I don't think you can. It's a real resource hog especially if youre using 2010/13. See below.
Excel 2003 is officially limited to 1 Gigabyte (GB) of memory.
This limit appears to be a limit on the working set memory used by the Excel process, which is the memory reported by Windows Task Manager.
Although Excel 2003 has a substantially increased memory capacity, many of the individual specific memory limits listed below have not changed in Excel 2003.
Excel 2007 is limited to 2 Gigabytes of memory for the Excel process under Windows XP/Vista (Windows memory limit).
This 2 Gigabyte limit is a limit on the Virtual Memory address space. Virtual memory used by a process is larger than the working set memory reported by Windows Task Manager, so the amount of useable memory under Excel 2007 is considerably less than twice that of Excel 2003.
Because Excel 2007 (Excel12) also requires more memory to store the indexes to the increased number of rows and columns you may not be able to load larger workbooks under Excel 2007 than was possible under Excel 2003. Memory Fragmentation may also mean that it is difficult to make use of all of the available 2 GB of virtual memory.
Many of the individual memory limits listed below have been removed in Excel 2007.
Excel 2010 is available in 2 versions: 32-bit (2 Gigabytes of virtual memory) and 64-bit (8-Terabytes (which is 8000 Gigabytes of virtual memory)).
The 32-bit version has the same memory limits as Excel 2007, but the 64-bit version, when used with a 64-bit Windows operating system, will have extremely large memory limits.
Note that the different versions of Windows Vista 64-bit and Windows 7 64-bit support differing amounts of RAM.
Aug 17, 2014 | Microsoft Excel for PC
Truck starts but then stalls in 30 seconds
It may be the ignition module. For example, my FORD F250 has a module on the distributor. Inside that is two seperate circuits, starting and running. The first will tell the computer to fire the fuel injectors for starting and then after that the running circuit tells it to fire the injectors for the running of the engine. I think it fires rich for startup and lean for running. These are cheap from Romania online so you don't have to pay rediculous prices like $70 or something. Also, you can use artist style Pure Titanium Dioxide White in Walnut Oil instead of expensive Silicone Compounds to mount them on the distributor if it is a FORD. Both will transfer heat but eventually the module will burn out one of the circuits in about 9 to 11 years of running. Mine burnt out the start circuit but I could still prime the 5.8 L engine with a sunlight squirt bottle and it fired right up and went on to the start circuit OK.
Dec 08, 2011 | Cars & Trucks
My 1990 lumina euro has 125000km on her and runs fine for the most part. Except when she gets warm i will shut her off and when i restart her the engine light is on and she has no tach and idles high. I...
1990 lumina and its a her ? is she 2.5 or she 3.1 it doesnt matter its both the same system we will treat it as one type same **** but gets in to heat. To begin with the ICM is the one that sends RPM information to the ECM. without this signal this girl gets blind sided. You are a OBD 1 stratagey, and the IAC is a stepper motor, it should of retracted and not delay. When you shut down the and start the car the ECM fire in every order in everyway untill it catches then it uses cranksignal and cam signal to synchronize the system and control idle. But the girl doesnot see RPM so she take a while to bring to fuel control. here the steps to to make the girl behave, check the coolant level make sure its filled, The ignition control is not reporting the tach to ECM.it either she went to open loop quickly and that is why I want you to make sure she is filled in the radiator.inspect the coolant temperature sensor and the terminal make sure its good the temperature sensor is at the left front below coolant outlet. And why did you do VSS it has nothing to do with RPM its just a transmission thing, so this girls fix ICM(she needs a tach to send out and the synchonize process begins when the ECM see's it) coolant temperature system went to open loop(that only if she stays full of coolant or water),then she wont be a *****
Apr 30, 2011 | 1990 Chevrolet Lumina
Can anybody help me with my krybord semes too be in t9 mode please
The VAIO Hardware Diagnostics utility can be used to perform various tests to ensure the computer is working properly and diagnose hardware issues when they occur. Follow this procedure to perform a Quick Test or Individual tests using this utility.
  1. Close all open programs. NOTE: If the VAIO Recovery Center application is already open, proceed with step 3.
  2. Open the VAIO Recovery Center application. NOTES:
    • If the VAIO Hardware Diagnostics window is already open, proceed with step 4.
    • The VAIO Recovery Center software can be accessed from the Start menu. Click the Start button, click the VAIO Recovery Center folder and then click VAIO Recovery Center .
    • If you cannot start the operating system, the VAIO Recovery Center software can be accessed by pressing the F10 key at the BIOS screen, but all the hardware component tests may not be available.
    • You also can access the VAIO Recovery Center software by booting the computer using the Recovery Discs. Insert Recovery Disc #1 and then restart the computer.
  3. In the VAIO Recovery Center window, under Choose a program , click VAIO Hardware Diagnostics .
  4. In the VAIO Hardware Diagnostics , click the Start button.
  5. On the Quick Test tab, click the Run Test button. NOTES:
    • To perform any of the individual tests available within the VAIO Hardware Diagnostics utility, click the Individual Test tab.
    • The Individual Test tab is only available when the VAIO Recovery Center is started from within the operating system.
    • Tests can be run on the following components: CPU, Memory, Video, Hard Disk Drive, CD-ROM, DVD-ROM, Network Adapter, USB, CF/PC Card, and Memory Stick.
    • The CPU, Memory, and Hard Disk Drive tests are performed during the Quick Test. The Video and CF/PC Card tests are also performed as part of the Quick Test when the VAIO Recovery Center is started from the desktop.
Dec 12, 2010 | Sony VAIO PCV-W1 PC Desktop
I GOT MY NEW ESET NOD32 ANTIVIRUS 4 DISC. CAN YOU GUIDE ME HOW TO INSTALL IT. I HAVE VERY LITTLE COMPUTER KNOWLEDGE. THANKS, LUCY.
well lucy pop it in the disc drive and follow along not much else to tell ya, not hard you can do it girl have faith in your self we can do any thing we put our minds too, we where all given that gift !!! and run your **** cleanup under (accessories) in the (start menu) check all boxes before you do any of this ok.
and here is what you should be running for a antivirus setup (AVG free) then get the full upgrade asap, next get (free super anti spyware program) and next (free ausdefrag program) you can download all of them from download.com just use the search pane and put exactly what I gave you for the names in and download them install them and run them the installs will guide you through it pretty easy ok don't sweat it girl, good luck and have a nice day the fixist
Aug 03, 2010 | Computers & Internet
Are the switches replaceable individually.
each switch is seperate,in a carrier.just pull out to replace(carefully and square).
Apr 27, 2010 | 1999 Audi A4
Uploading multiple days of runs to Garmin Training Center
Yes it will hold ALL you runs AND keep them seperate. What you need to do at the end of each run just before you turn it off hit and "hold" the Lap button (reset button). It takes a second but you should see it say reset in 3-2-1. Keep holding untill the process is finished. What this does is end your run and saves it in the watch. When you start your watch the next time it will start a new run when you hit start. By doing this it will keep everything sorted when you down load. In the software you will see one enty with a + sign beside it. The first entry you see is the total of the week. If you hit the + you will see each individual run.
Hope this helps.
Mar 18, 2010 | Garmin Forerunner 305 GPS Receiver
Unknown file
In software Svchost.exe is a generic host process name for services that run from dynamic-link libraries (DLLs) within the Microsoft Windows operating system.
At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services permits better control and easier debugging, but it also causes some difficulty for end users wishing to see the memory usage or vendor legitimacy of individual services and processes. End users in Windows XP Professional (and derivatives, such as Windows Server 2003 and Windows XP Media Center Edition) can run the following command at the system prompt to get a breakdown:
tasklist /svc /fi "imagename eq svchost.exe" (NB: This command does not work in Windows XP Home.)
Due to being widespread among running processes, svchost.exe has long been a common disguise used by malware to hide its presence from the user. (One of the common trojan horses deceptively uses scvhost.exe). Users may then run tasklist with no arguments and match the reported PIDs with the previously shown Svchost instances. If memory usage appears abnormal, the user can look up the service names shown by their command on the internet to see if it is a known service or malware.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. The main registry key involved at bootup is HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost (values in this key will show the user at least a partial list of the actual processes behind instances of svchost).
The 30 April, 2007 release of WSUS 3.0 led to reports of svchost.exe issues, including 100% CPU usage, memory hogging, and excessive laptop fan/power usage.[1]
[edit] See also
Oct 29, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
196 people viewed this question
Top Pc America Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Will Halftowaite
sunil dixit
Are you a Pc America Computer and Internet Expert? Answer questions, earn points and help others
