Question about HP Office Equipment & Supplies
Machine does not recognize toner cartridge. When I put cartridge in machine it says "install black cartridge."
    Master:
  • 416 Answers
Probably electrod is durty. If it is genuine cartrige you might need to clean the cooper electrode with clean foam-rubber swab or lint-free cloth slightly dampened with water. Use a clean dry foam-rubber swab or lint free cloth to remove the moisture from the contacts. Do not touch or wipe the nozzle plate on the bottom of the cartridge
More information is here
Good Luck
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpd04230&jumpid=reg_R1002_USEN
Posted on Jan 12, 2009
  • 916 Answers
Please remove the toner and reset the machine. If it is still not working you may need to have the machine cleaned by a professional with a non-static vacuum.
  • HP Master
  • 19,396 Answers
To start, remove all toners, and unplug the machine for ten minutes.
Then restart the toner install procedures.
If this does not fix the problem, the machine must be cleaned inside, as toner residual may prevent from recognising toner cartridges.
See Clean your laser printer safely with these tips
  • HP Master
  • 6,487 Answers
Can you please provide us the model of this printer so we can help you better, and you can also try to remove the cartridge again and put it back in and then power off the printer for a minute then power it back on...
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
Replaced yellow and Magenta to receive replace messages for both.
yes you reset your printer resume button press 2 times then solve your problem inshallah
Aug 12, 2009 | Samsung CLP-510 Laser Printer
Canon MF-6550 ''toner not set''
check properly to toner if there is some stickers left on it and put it tightly to recognize it...
Jul 17, 2009 | Office Equipment & Supplies
HP Laserjet 3005DN toner cartridge change
You don't. HP printers seem to be very particular about this.  Take it back and get the exact replacment, including the brand.
Jan 20, 2009 | HP LaserJet P3005n Printer
LDell 3100cn awer printer won't recognize new toner
Have you removed the plastic protection strip from the bottom of the toner?
Nov 14, 2008 | Dell 3100cn Laser Printer
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
New cartiage/not reconized
It says there is no cartridge, or does it say that the cartridge is empty?
First, you must realize there are two cartridges. A drum and a toner. If you bought a new toner, pulled out the drum and put the new toner in, you have pulled a DOH! You can't just put the toner in. You have to take your old drum cartridge, remove the toner portion and install the new toner into your old drum and then install the entire assembly back into the machine. I hope you didn't throw your drum out thinking it was all one cartridge (I've seen it happen). This is where reading the owner's manual helps.
If not, then one of the contacts must have been damaged. Remove the cartridge and look inside the machine. See if you can find any of the metal contacts on the side of the inner chamber that is bent or damaged and try to bend it back.
Check the drum and make sure none of the contacts are damaged.
If the unit is still saying Toner Empty, try this. On the left side of the toner there will be a while lever in a semi-circular notch.
Unplug the unit, use a small screwdriver or a key to push that white lever back to the front of the notch. Put the drum and toner back into the machine and plug the power back in.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
24 people viewed this question
Seeker5211
Seeker5211
