Question about HP Officejet 7130 All-In-One InkJet Printer
Paper jam constantly on
"Paper jam: Clear jam, and then press enter" notice on screen. I've blown, sent cleaning paper with solvent through with no success.
Ed
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
Cannot clear paper jam
Paper Jams in the Automatic Document Feeder
If you're loading legal-size paper, insert only 10 sheets at a time to prevent paper feeding problems.
If paper jams inside the ADF, clear the jam and reload the paper as follows:
1.
Open the ADF cover and remove any jammed paper.
Caution:
Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism.
2.
Press OK, then select Yes and press OK to clear any messages on the display screen.
3.
Reload the paper. Make sure the corners of the paper are not bent, folded, or curled up.
Jan 11, 2011 | Epson WorkForce 600 All-In-One InkJet...
Unable to print or copy, see troubleshooting 51
The error means you have a paper jam or one of the sensors is incorrectly reading a paper jam. Unplug the unit and check all areas for a jam. Remove the back Jam Clear Cover and check inside there. Remove the Paper Tray and check that area and check if the PE actuator is in place behind the paper tray. Lift the scanner flatbed unit and check inside the print carriage area. Look for scraps of paper at the sides of the platen. These scraps that may be soaked with ink and difficult to see. You may need to move the print head to see both sides.
If the PE actuator is missing, contact Brother for a replacement. Put in the replacement if needed.
Close the scanner unit, replace the clear jam cover (put it on correctly) and replace the paper tray. Plug in and turn on the printer and see if the message clears. If it doesn't clear, access the Ink or Ink Management menu (either directly by a single key or through the menus). Do a test print for Print Quality (Color). If the quality is good, press 1, the up arrow or + key to select Yes. Then press the Stop/Exit button. If the print quality is poor, clean the print head.
If the jam message occurs again, check for more scraps of paper inside the unit as above. Make sure your paper meets the specifications for the printer and isn't getting excessively humid. (Paper will pick up moisture from the atmosphere so keep only the needed amount in open reams or the paper tray.) Fan the paper in the tray and then return it to the paper tray. Make sure the paper is flat in the tray and that the guides are just touching the edge of the paper.
If it still doesn't clear, the unit needs service.
I hope this helps.
Sep 14, 2010 | Brother MFC 240C All-In-One InkJet Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cartridge jams
remove the cartridge and directly off the printer let the carriage remain in center.then with your hand manually move the carriage from left to right.3 to 4 times.then on the printer and insert the cartridge after cleaning it with dry tissue.then check out.also in the back side of the printer there is access door to remove the paper if jammed so check out there also if any paper jammed.
thanks.
Apr 01, 2009 | HP PSC 2210 All-In-One InkJet Printer
Paper jam
Is this happening regularly? Clean the rollers with Isopropyl alcohol. Dont use solvents. Everyday wipe with a damp cloth before starting scanning. Check if the paper thickness is standard and is not sticky.
S. Mohan, india
Feb 25, 2009 | Panasonic KV-S3065CL Path-Through Scanner
Please clear paper jam and press ok
hi i josh in cebu phils. may i help you? friend the paper jam means there is something blocked your paper feeder try to clean or check if there is something in there may be a paper pencil clifs etc. try to clean and restart the printer.good luck
Feb 19, 2009 | Office Equipment & Supplies
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Paper jam message on Magicolor 2300W
How do you clean the rubber rollers, hope you didnt use solvent....
Use dry cloth with dishwashing fluid only to wipe the rollers.  You will notice the increase in grip immediately.
Dec 17, 2008 | Konica Minolta magicolor 2300DL Laser...
HP Officejet 7130 All-In-One InkJet Printer Logo
161 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
