Question about Maytag Neptune MAH5500B Front Load Washer
Mah55flbww front loader spins but tub is still full of water.
But when i set the washer to a seperate spin the water drains out as normal.its also taking twice the time to wash.
  • 1 more comment
  • rebelsmilfor Feb 17, 2009
    mah55flbww front loader spins but tub is still full of water. but when i set the washer to a seperate spin the water drains out as normal.its also taking ...
  • Anonymous Mar 30, 2009
    it seems to be spinning but still full of water
  • peach2 Apr 02, 2009
    Spins but does not remove water
    Also fills with water between uses. It has flooded my laundry room 3 times.
  • 4 Answers
SOURCE: Front loader will not spin
Might be a burned (a few coils) motor - feel any burned paint smell?
Alternatively, a broken belt - you'd hear rthe motor spinning, though - or some sensor/wiring malfunction.
Posted on Jan 14, 2008
jsrock516
  • 5911 Answers
SOURCE: drain and spin cycle
Okay...the problem may be that you have something caught in the drain pump preventing the impeller from turning. Or, the pump itself may have stopped working. If you experience a problem where the washer does not drain or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Please read ALL instruction before attempting.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the screws at the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located under the wash tub (it is the only pump this washer has).
4. The pump can be removed and the housing taken apart to clean out the impeller trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and place them under the pump. Remove one of the drain lines and allow water to drain. If the tub is still standing in water (as you stated) bail as much from the tub before removing the drain lines from the pump (if you are using the towel method for collecting water).
6. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the housing cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select a wash cycle. Allow the tub to begin filling and check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping.
10. If there are no leaks, you can stop the wash cycle at any time and select a drain cycle. If the drain pump works normal, reinstall panel and tighten screws.
11. If your pump still does not run, more than likely, the impeller motor is damaged and the entire pump must be replaced. The motors typically are the part that fails on this pump. Follow the previously mentioned procedures for removing water from the wash tub.
NOTES:
a. Your pump is item #916709 at repairclinic.com. Or part number 134051100 at searspartsdirect.com. Just type in your model number in the search menu and a parts index with pricing is made available to you. the pump is listed as an "askoll pump" under the "Tub" header at the Sears website. HINT: Sears has it a little bit cheaper.
b. It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
I hope this information is helpful. If you have any questions/concerns, please post back with your comments. Good Luck.
Posted on Feb 28, 2008
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
  • 67 Answers
SOURCE: won't empty water slow spin in spin cycle
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
if this helps please vote a fix ya
Posted on Jul 15, 2008
huuum
  • 750 Answers
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Posted on Dec 05, 2008
What is leaking under my Amana washer during spin cycle?
Unlikely as the water is pumped out during washes and rinses. As you say it is only during spin, my view is that you have a crack or a split in a hose or a plastic part which is opening up due to the movement or vibration of spinning. The other possibility is a bad seal at the top of the drum on a top loader, or somewhere on the outer case of a front loader. A full strip of the outer panels is the only way. You can do a wash and then tilt the machine backwards against a wall and use a flashlight to look up inside.
Feb 19, 2018 | Washing Machines
My machine is barely draining water on the drain and spin cycle. It will spin but does not empty all the water out of the machine.
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Jun 08, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Front loader doesn't drain properly, water lwft in
Hi
Thanks for using FixYa. If your washer won't drain, check these:
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers try to grab and remove the clothing through the port.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 05, 2009 | Fisher and Paykel Washing Machines
Frigidaire Front Loader won't drain after cleaning out tube?
It won't drain If your washer won't drain, check these:
It pumps, but the water returns
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jul 14, 2009 | Frigidaire FTF530FS Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Frigidaire Front loader nightmare!
Apr 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Please help me with my washer
Hello browneyez070
Welcome,
You said, your Hotpoint top loader washing machine won't spin water out. Model VBXR1O6OVOWW?
Common causes before considering repairs.
Water won’t drain
Drain hose is kinked or
Improperly connected on it.
Solutions
• Top of drain outlet should be less than 8 ft. above floor.
• Straighten drain hose and make sure washer is not sitting
Let me know if these measures help.
Huuum
Oct 15, 2008 | Hotpoint VBXR1090B Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Maytag Neptune MAH5500B Front Load Washer Logo
135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
