Question about Coffee Makers & Espresso Machines
Group head seal replacement on sunbeam em5600
3 Suggested Answers
SOURCE: I'm looking for the manual
You can get the manual from Sunbeam's site, there is a link for a PDF download of the manual, please use the link below.
http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1130
Posted on Dec 24, 2010
  • 1833 Answers
SOURCE: Sunbeam EM5600 Machine is 4-5 years
You may take the following steps:
1. Adjust your grinder to a coarser setting.
2. With the machine switched off, visually inspect the steam nozzle to see if it is physically blocked (for example, milk may have lodged and solidified in the mouth of the valve). If it is blocked, you should be able to clear it with a small pin.
3. You may also need to prime the unit (to clear out any air pockets that may have formed). Make sure the water tank/reservoir is all the way in. Place a bowl under the steam wand (and if applicable, under the hot water wand as well). Turn on the steam wand (and if applicable, hot water wand) and let it run for 3-4 minutes. This should help clear any "air lock".
I think in this way your problem will be solved.
Posted on Aug 10, 2011
How do we fix a Sunbeam coffee machine that isn't heating?
Fluid has gotten into the system and caused an electrical fault ?
Jun 25, 2014 | Sunbeam Coffee Makers & Espresso Machines
Em6910 collar replace
The whole collar or do you just mean the blue silicone seal?
You can buy the blue seal on eBay. Simply undo the Philips screw in the centre of the 'shower' in the group head, take out the two shower screens and the blue seal will be fairly easy to remove.
May 09, 2014 | Sunbeam Cafe EM6910
My silvia is at least 8 years old and is serviced on a regular basis.
The 'group seal' in the underside of the head that the grounds arm compresses against probably needs replacing. If you unknowingly left a few grounds to dry on the underside of the seal the last time you used the machine, this can be enough to cause a leak the next time around.
If replacing the group seal, replace the 'shower screen' above it as well. Always buy genuine Rancilio parts, you should be able to find both for around $10 - $15 each on Ebay.
There are videos on either You-Tube or Gooble that show how to replace these parts on the Silvia.
Always try to ensure the seal face is cleaned before and after use and the group seal will last longer, but they are actually meant to be replaced whenever necessary, they are not designed to last forever.
Jan 13, 2013 | Rancilio Silvia Espresso Machine
Replace group head seal ascaso ARC
Hi There, If you need a group gasket for the ascaso Arc
Try links below. If machine is the older model Ascaso gasket kit Dream Arc Basic If made after 2012 Ascaso group gasket Set 2012
Jan 04, 2013 | Ascaso ARC Dark Black Espresso Machine
How to change shower headplates and seal on EM6910
Shower headplates should never need replacing. If they get clogged, pop them in a bowl, our vinegar over them and leave them for 10 minutes.
Dec 16, 2012 | Sunbeam Cafe EM6910
My Sunbeam coffee machine model EM900 twin thermolock cafe series.Was leaking water around group head . Have replaced the grouphead seal but still leaks infact worse My machine is 7yrs old but in good...
I have a Sunbeam twin thermoblock Im having trouble with my steam wand I im not getting much steam out for the milk to warm up try to clean it with a pipe cleaner can you give me an advise how to get it woking
Feb 01, 2011 | Sunbeam Microwave Ovens
I'm looking for the manual for Sunbeam cafe latte EM5600, we have had it for a week and misplaced the manual so it hasn't been used yet
Oct 08, 2010 | Sunbeam Coffee Makers & Espresso Machines
Sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Mar 26, 2009 | Avanti Hot and Cold Water Cooler
Coffee Makers & Espresso Machines Logo
233 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
