Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Fridge just stop getting cold and is defrosting
I went to get some ice out of the fridge and noticed everything melting.  The fans are blowing and I unplugged it and plugged it back in.  The compressor sounds like it's going to start, than it stops.  Does it about every 2 minutes.
  • nikvelikiy Jan 12, 2009
    Five year old side by side Kenmore 53642 stopped cooling and freezing two days ago. Lights are working, water dispenser is working, all vents are clear, but blowing warm air. Opened rear bottom cardboard cover, Fan is working. Unplugged power cord, re-plugged power cord, heard click from oil cooler, fan working, but only warm air from vents in both freezer and refrigerator sides. Water dispenser works. What is most likely problem, and about how much will it cost to repair. We have already spent about $500.00 in repairing our ice-maker twice, and other minor problems. Not sure if we want to spend any more on repairs, or buy a new one. Our old refrigerators ran for over thirty years. Not sure if this is "Kenmore" problem, or planned obsolescence. Any advice will be appreciated.
  • 700 Answers
Sound like the start compoinents may be weak on the compressor, the parts is approximately 35 dollars . take the model number and make to a apliance store and they should be able to get the right part for you.
Posted on Jan 15, 2009
I have a Beko frost free fridge freezer kept in a garage that has all of a sudden just stopped working. I noticed that the bread I'd put in the freezer hadn't frozen and then noticed that the fan had...
If the fan has failed or intermittent, the freezer wont freeze the food properly but usually you get a mountain of ice build up at the back of the freezer. This ice jams and stops the fan from turning. Alternatively, there could be a defrost problem. Unless it is a fully electronic defrost machine, there is usually a little timer on the back of the fridge to force a defrost after a certain time. The fridge will turn off, the defrost heater operates to melt the ice and then usually with 20 to 45 minutes, the defrost timer will "click" back on and start the fridge running again. If the timer is sticking, the fridge may stay on its defrost cycle and never start again, thus, it doesn't get cold. If you find the defrost timer, have a close look for a little shaft or slotted screw type stud sticking out of the middle of it. A slight turn of this and you should hear it clicking around. When you hear a loud click, that is either the start or end of the defrost cycle. If you have a full electronic defrost system, it may be a failed board, heater, thermostat or defrost safety fuse.
Jan 05, 2015 | Refrigerators
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
I have had my fridge for 6 years now and the fridge is not staying cool???
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Jan 16, 2011 | Fisher and Paykel E522BRXUSS Stainless...
Freezer is cold but refrigerator is not
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Jan 07, 2011 | Kenmore Refrigerators
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
Kenmore refrigerator stop cooling but fan working
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
Admrial LTF2112AR fridge not cooling
How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 12, 2009 | Refrigerators
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge/ Freezer not cold
My fridge started making a weird noise not too long ago. Now the fridge isn't cold and everything in the freezer is melting. The read out still says that everything is the right temp, but the melted ice tells me otherwise. Recently my daughter found out how to operate the buttons and has been pushing them a lot, but we change them quickly.
I would have the refrigerator / freezer checked out by a serv tech mainly because if it is a compressor, this would not be something that can be done by as customer, but it could be something internal like a fan or a fan motor that blows the cold air or a bad thermostat or sending unit – the weird noise is something internal that really should be check out by a serv tech before you lose everything as far as food, etc. – the refrigerator is a sealed unit and is hard for a customer to service unless they have serviced the unit before.
Apr 08, 2008 | Samsung RB2155SH Bottom Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
