Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Motorola mts 2000 won't turn on
Had the battery by itself plugged up in the charger for about 18 hours, and now it won't turn on. is the battery dead? or have I fried it?
  • Motorola Master
  • 1,654 Answers
It is doubtful you ruined your battery, as they are designed to be left charging for periodic long periods, such as a full weekend, when a business is not open.
If you battery previously worked before charging it, I would suggest checking the connection to the radio, and the battery contacts on both the radio and the battery. It is possible you have flattened one of the contacts or some other contact problem.
If the battery did not recently work, it is possible it simply needs replaced.
Lastly, you might want to verify your charger is working. It is possible the battery did not get charged, and is completely dead. This is the least likely scenerio, as it is rare a battery is stone dead, unless it is no good.
Try a battery from a known good radio on the effected radio and make certain the radio is functional. If so, check the contacts, if okay, replace the bad battery.
Best regards.
Posted on Jan 12, 2009
Hp dv4000 won't turn on, no lights on- totally dead
first check fuse in plug. if good then check power adaptor, even if its lit up it still can be faulty or use a voltmeter to check that you are getting continuous current. if good it gets harder youll have to open it up and check the fuse inside it dont look like a normal fuse its small. its at the back next to were you plug in the charger should say f. check picture. its not for youre model but just a demonstration. hope this helps. j.oates
Nov 16, 2012 | HP Pavilion dv4000 Notebook
Why does my Motorola Admiral not turn on automatically when it's plugged into a charger?
it's not to worry about your phone when your phone does not start automatic because in the only region off your better dead. you just live your phone into a charge sometimes after you can see your phone is automatic restart
May 17, 2017 | Cell Phones
Hi, my drill has just stopped working i have changed the battery but it seems dead ?? the drill is about 3 years old but has only been used a hand full of times as it a personal home diy tool ?????
When you put the battery in the charger, does the light go on? The charger has lights to indicate whether the battery is fully charged or not. If it is dead when you put it in the charger and remains that way after one hour, you can be pretty sure that the battery is dead. If there are NO lights on the charger, plug it into a different outlet and recheck. Not using the drill for long periods of time is really not good for the battery. The drill is probably ok, but the charger or battery could be the problem.
Nov 15, 2009 | Dewalt 18 Volt Compact Drill Kit
Motorola Z3 Rizr won't turn on
when you plug in the charger cable to your phone, make sure that you allow it to charge at least 2 hours, if your phone shuts off immediately after this amount of time, you likely need a new battery, they will wear out after a certain number of recharge cycles.. contact your motorola distributer or motorola website to purchase a replacement. Note do not accept "Non-Motorola Batteries or chargers as these are not guaranteed to provide the proper current necessary to safely recharge your battery, if you notice the battery getting Hot, then disconnect the charger immediately and let it cool, before removing and disposing. Remember it is normal for the battery to be warm to touch while charging or the phone itself is in use. but if it gets hot to the touch this is not normal, and the battery needs replaced..
Nov 06, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Bluetooth not charging
The internal battery is bad or your charger is faulty, got a kink in the cord.
Jan 22, 2008 | Motorola Mobility H700 Wireless Headset
MTS 2000
The radio can only be programmed or adjusted by the use of a computer and the proper software. What exactly is it doing or not doing? Do you keep it on the charger all the time?
Dec 20, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Razr wont chage
GO TO SETTINGS" .... SCROLL DOWN TO "PHONE STATUS" AND CLICK ON IT. iF IT SHOWS "DEAD" BUT YOUR PHOPMR STILL POWERS UP ... YOU HAVE A FEFECTIVE CHARGER, ALSO ... TRY DRAINING THE BATTERY. THEN SHUT THE PFONE POWER OFF FOR TILL THE CHARGER IS COOL TO YJR TOUCH. LEAVE YOUR PHONE OFF AND PLUG THE CHARGER IN FOR 3-4 HOURS. oNE OF THE TWO SHOULD TELL YOU WHAT IS BAD
Jun 30, 2007 | Motorola Mobility RAZR V3
What is the master reset for a v6 razr???
go to main menu then settings. click initial set up scroll it there you will see master reset. click master reset you will see enter security code type 000000 then enter it will reset itself wait it will shut down by itself and activate again
Jun 24, 2007 | Motorola Mobility MOTORAZR maxx V6...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
131 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
