Question about Microsoft Wireless Notebook Optical Mouse bx300008
No light on Wireless notebook optical mouse 3000
The usb connection has agreen light but there is nolight on the mouse. I have reimstalled the software and changed the battery. i have depresses the black point on the bottom of the mouse to no avail. The battery in the mouse is very warm to touch. can you help please?
  • 1 more comment
  • mack84 Jan 12, 2009
    Thanks for a prompt reply. I tried the suggestion but it did not make any difference. the mouse still has no indicator light at all.
    changed batteries but no change . will buy another mouse if necessary but still hope for solution
    I have a light. It worked I made an error with the battery. however the mouse is not still working. It is a red light and no coneection to the screen pointer ? Any further suggestions please?
  • 916 Answers
  1. Restart the computer
  2. Make sure the mouse and receiver are not to close together sometimes it interferes with the signal
  3. Make sure that the receiver and mouse are using the same channel
  4. Press the connect button on the receiver to restart it that way
  5. Check to make sure you have the latest driver
  6. If none of these work you may need to replace your mouse
Posted on Jan 12, 2009
  • 58 Answers
You most likely need to replace the mouse as the batteries are getting hot and the mouse will not work. Wish you the best of luck.
  • Microsoft Master
  • 19,396 Answers
If the mouse is wireless , then you need to do synchronization again.
If mouse is wired one, then you have a broken mouse, maybe the cable, as an usb mouse turns the light on when you connect to USB, even if software is not installed.
Verify also that usb is working.
  • 81 Answers
First off the USB port would not affect the actual physical mouses power problem. Unless it wasn't wireless but this one is. The only thing I can come up with is the battery is in backwards. As silly as it sounds. A battery will short circuit and over heat if put in backwards. Let me know if this helped.
  • Ern More
    Ern More Jan 12, 2009
    Now you will have to go through all the steps you did before. Reinstall driver/software, link again by pushing link buttons on both units, etc. Hope this helps. Thanx for the rating!
  • Microsoft Master
  • 13,433 Answers
suggest you try another set of batterys and if the mouse still doesn't work and the batterys get hot, there is something wrong with the mouse, I can't say exactly what is wrong, you may have a faulty mouse and it would be best to replace it as they don't cost much.
  • Ekse Jan 12, 2009
    It was too obvious I overlooked it, I know you wont get my message anymore but, you need to reconnect the mouse to the computer and pair it with the station with the connect buttons.
  • Microsoft Master
  • 6,487 Answers
Try to connect it on a different USB port because sometimes its just a problem with the USB port even though the light is on...
  • Mark Gil
    Mark Gil Jan 12, 2009
    If that's the you may need to try it on a different computer to check if that is already bad , since the light wont even came on...
How to connect my wireless mouse to the pc
the wireless mouse should have come with a small usb stick
plug that into the pc usb port and the pc will go into installing hard ware mode and down load the driver for it
Oct 25, 2015 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Notebook optical mouse 3000 not working
Have you tried changing the port in which the USB wireless receiver is plugged?
Or is the receiver internal to the notebook?
If the receiver is internal, try updating the drivers for your machine by navigating to the manufacturer's support site.
If you plug a wired mouse into the machine what happens? If you get the same result, it may indicate a problem with the USB settings on your machine. I would, again, suggest updating the drivers for your machine.
If that's the case, try plugging another USB device into the machine and see if it works properly.
If none of those options provide results, I recommend you return the mouse for a refund or a replacement, especially if you have the receipt.
I hope I was able to help you. Good luck!
Aug 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 'Quit'
I would try taking the usb and puting into and diffrent usb port and also if you have another computer try it on the other computer
Jun 04, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Op. Mouse 3000 Dosent work.
try plugging the usb adapter into a different usb port of the computer and there must be a connect button on tat adapter..press the connect button on tat aadapter and then press the connect button on the mouse {after replacing the battery}.if it doesnt work on 1st go ,,try 2-3 times,,,and hey best of luck
Apr 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
My microsoft model no 3000 wireless notebook is not working.
I suggest to put a new battery in it's compartment and simultaneously to press down and release the small button that protrudes where the receiver is placed at the bottom of mouse. Prior to this procedure the receiver has to be installed in the USB port. Both actions are to be performed at the same time. Cursor will start moving again.
Good luck!!!
Chawah.
Mar 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 help
I had the same problem.
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
Mar 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 not working
Most devices last a long time. Have you tried re-installing the software for the keyboard & Mouse> Also go to microsoft download center and get the latest drivers for you setup. Make sure when you do, choose the right Operating System driver for your Keyboard & Mouse. Hope this helps. Bud
Dec 30, 2008 | Microsoft Wireless Optical Mouse
Do you have another device to test the batteries in to be sure they are good? Also verify the batteries are inserted properly - if so, it appears the mouse has just quit working.
Dec 29, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Optical Wireless Mouse 3000 MSK 1056 does not work !
I fixed an MS wireless mouse that was not responding by pressing the button on the receiver while it was connected to a USB port & then pressing the button on the mouse. Worked fine after that.
Dec 23, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse bx300008 Logo
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
