Question about Garden
Replacing honda GX340 engine oil level sensor
How to Replace honda GX340 engine oil level sensor on a pressure washer
  • 1388 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
SOURCE: pressure washer oil
SAE 30, or 15W-40
Posted on Aug 01, 2009
  • 174 Answers
SOURCE: Pressure washer with 5hp Honda will ONLY run with choke on
It sounds like it has been tipped or too much oil has been put in. This would explain the oil in the air filter. First check the oil level. Then you need to clean the oil out of the carburetor. It is dirty or plugged and that is why it only runs when choked. You can try a spray-in carb cleaner but the best thing is to remove it (if you are handy enough) and soak it in varsol for 24 hours. Good luck
Posted on Aug 11, 2009
SOURCE: I temporarily misplaced (not lost for good) the
http://www.ultimatewasher.com/download/honda-engines/gc160.pdf
Posted on Sep 12, 2009
  • 615 Answers
SOURCE: I have a Honda 3500 pressure washer. The motor
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 20, 2009
Testimonial: "The problem was the governor spring. Thanks"
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Pressure washer rope recoils to quickly when pulling to start
I'm sorry if I'm not quite understanding the question.
Are you saying the rope MAY be too short and so the amount of pull available is also shortened?
Feb 23, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
How to replace valve timing gear in honda gx340 engine
Align crankshaft and balancer gear first. Rotate crankshaft and align timing gear. Alignment mark may be hard to see on crankshaft for timinig gear.
Jul 09, 2012 | Honda Gx340 Gas Engine 11hp Motor Pressure...
I have a Honda GX340 power washer and would like to know what types of oil and quantities I need for the engine and pump
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Honda Pressure Washer PSI 3000
Honda Trash Pump Model WT30X Stalling - 8hp engine runs for approx 5 seconds that shuts down, restarts after I hear a relay click ? oil is fine - so I do not believe that it is an oil pressure...
Their is an oil level sensor that lasts around 3 months of use. unplugging it would solve your problem But replacing it is a night mare. and if your oil runs out It's all over. if not the oil sensor, and your spark is constant Check your fuel system for water and debrie. Those pumps can run dry all day long.
Apr 06, 2010 | Honda 8 HP Engine
Oil grade and level in pump reservoir? Motor is shutting down, all else seems fine, assume is oil level. North Star with Honda GX340 - pressure washer.
15-40 there will be a fill mark that is easy to see when you remove the cap or it will have a dip stick
Second your oil pressure switch may be bad or have a bad connection
Mar 06, 2010 | Hardware & Accessories
Timing a 13 hp GX 390 Honda engine
I believe it is either one but if you are not sure, stick a screw driver in an see if it comes out with oil on it. Does one not have an oil level stick attached to the cap?
Jun 18, 2009 | Honda Pressure Washer PSI 3000
Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Jun 01, 2009 | Honda Pressure Washer PSI 3000
Pressure washer stalls
Nov 15, 2008 | Honda Pressure Washer PSI 3000
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
