I replAced the motherboard in my Maytag ecoconserve washer and need help calibrating it.....can I do this without a handheld device or what? The model is mvwc400xw3
2 Suggested Answers
SOURCE: maytag ecoconserve wont stop draining
something might block the drain valve that prevent it to fully close those cause the water to continue to drain...
Posted on Nov 18, 2012
Maytag top load washing machine repair
It sounds like your Maytag (now owned by Whirlpool) Actuator needs to be replaced. Last year our Maytag Centennial top loading washer Model MVWC300XW0 would not drain all the water and cloths would be soaking still. Doing some online research, I came across some very helpful video regarding replacing your Actuator.
The only thing I would recommend to future installers is get your Technician Manual located just inside the case (front panel) first of your Washer. The Technician Manual is taped inside your washer in a plastic bag. Once you replace this Actuator part, I recommend that you run the Calibration cycle on your washer. It is needed anytime you replace a motor, motherboard or pump.
Here are two videos describing how to change/replace the Actuator but these videos are basically for the MVWC300XW0 model. I'm sure if you search for your model, there will be other videos as well.
Two videos on how to replace your Actuator:
1: https://www.youtube.com/watch?v=YVjTY-Hj4jw
2: https://www.youtube.com/watch?v=yTHryoT78pA (This is video that I viewed the most)
Best of Luck!
Jun 05, 2016 | Maytag Washing Machines
Maytag maxima ecoconserve washer My washer will not operate. The lights come on as if it will I hear a few noises, but water will not enter it and it does not operate. Error Codes are E02 and F06
you have a communication error from the UI (user interface) to the CCU (Central Control UNIT). It could be the wiring or the control itself
Feb 06, 2016 | Washing Machines
Can you adjust the water level if you want more water for your wash cycle?
it may be possible if the water level pressure sensor has an adjustment for the pressure setting
or you could simply select full wash each time
Jan 07, 2016 | Maytag Centennial EcoConserve Top Load...
Some white spots on clothes at the end of wash cycle?
Not sure if you use bleach but you could have bleach spots if you do.
Mar 18, 2015 | Maytag Centennial EcoConserve Top Load...
LA PANTALLA TACTIL NO FUNCIONA
google translated
TOUCH SCREEN NOT WORKING
DO NOT OPERATE AS TOUCH PANTLLA
Touchscreen computers and handheld devices are the newest wave of technological gadgets as of 2010. While these devices function impressively, they can malfunction just like any other technical device. Troubleshooting the touchscreen is simple and often will correct any issues.
Identify how the screen is behaving. A touchscreen will malfunction in one of two areas--sensitivity or position. If you touch the screen and the cursor is not centered on your finger, this is a position error and requires recalibration of the screen. If you touch the screen and it does not register your touch without pressing hard, this is a sensitivity error. If you touch the screen and nothing happens, this can be a sensitivity error or a malfunctioning screen. Calibrate the screen. For all main errors, calibrating the screen will correct the issue. Every device has a different method of calibration but can usually be found under a "Tools" or "Diagnostics" menu option. Reload the device. For handheld devices, remove the battery and let the device rest for no less than five minutes. For computer or computer system devices, power down the device, disconnect the touchscreen device from the computer and remove any power cords to it. Allow the device to rest for five minutes. Reattach the device or reinstall the battery and power up the device. If issues persist, reload the software for the device. For handheld devices, do a full wipe of the device and return it to factory specifications. For add-on devices to a computer or computer system, uninstall the device and reinstall the drivers. If reloading, registering or calibrating the device does not work, consult the manufacturer for possible warranty replacement options.
Feb 26, 2013 | Computers & Internet
Maytag ecoconserve wont stop draining
Nov 18, 2012 | Maytag CentennialR EcoConserve Top Load...
Washing Machines Logo
Top Washing Machines Experts
