Question about Toshiba Libretto 70CT Notebook
Screen has no power
I just received a used Toshiba Libretto 70CT notebook and was told it had some issues. When I power up the device I see the lights turn on to indicate power and hear the hard drive and fans starting. The screen remains black and does not receive power. I am wanting to know how to troubleshoot this problem. I am guessing it could just be a bad connection to the power or that maybe the screen has died. All information is helpful! Thanks
  • 34 Answers
1. take a flashlight and light on the display after you started the computer and waited for about 5 minutes, if you can see the windows environment the inverter needs to be replaced (normally it's in the display frame under the display)
2. attach an external monitor to the laptop and boot. if the monitor shows something you don't have a defective graphic-card (maybe you must push fn + one of the fn-buttons showing a monitor)
if you don't get anything displayd by an external monitor the graphic-card might be defective - you would need a "new" motherboard then
Posted on Jul 20, 2009
Toshiba libretto 50 ct wont boot
I haven't encountered multiple beeps on shutdown - but multiple beeps on startup is usually an indication of a memory issue. Frequently can be resolved by simply taking memory modules out and re-inserting them.
If problem continues, may need to replace memory chip. If more than one chip, put one in at a time and startup to see which chip is causing the problem.
Not sure, based on your description of the problem, if this is the issue - but certainly worth a try.
Best of Luck!
Jan 03, 2013 | Toshiba Libretto 50CT Notebook
Reset to factory default
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
May 19, 2012 | Toshiba Libretto 50CT Notebook
I just bought a Toshiba PA1260U-T2A 70CT/1.6 with the IO adaptor. Every thing seems to work on it and it has windiwo 98. However How do you load programs into it? I can't find any manuals for it...
On those laptops you want to check the size of the hard drive and the ram on them before you do anything to them! They didn't make them too fast or with a big HDD so you might not be able to really install anything on it. You could always buy an external cd-rom and install programs through that since we no longer us the floppy didks and you won't find anymore programs on them... Let me know if this solved the problem and good luck..
Sep 09, 2011 | Toshiba Libretto 70CT Notebook
Screen is grey in color. everything is running. can use a external monitor. i have replaced the screen, inverter, and cable, still a blank grey screen.
my toshiba notebook was turning white for a long time. called toshiba they wanted $ and its only 18 months old and of course out of warranty. took it to authorized dealer and they fixed it was the cord from the bottom of notebook to the screen 160 bucks. the authorized dealer told me it was common with toshiba as they do not put enough insulation around the cord and it starts to fall apart. he even showed it to me and it was frayed here and there from opening and closing the notebook. and the cord runs thru the hinges. UGH But toshia insists it is not a huge issue i told them search the internet its a huge issue and so is over heating with their notebooks. never toshiba for me again.
Jan 26, 2011 | Toshiba Satellite A135-S2276 Notebook
My toshiba libretto laptop won't turn on how do i fix it
first, I will advice that you check the adapter, see if its still working. The adapter might be the reason your laptop is not working.
If you have confirmed that the adapter is still good, let me know so that I can direct you further.
Take care.
May 28, 2010 | Toshiba Libretto 50CT Notebook
Does anybody know if a Toshiba Libretto U100 can run on a DDR PC2700 333 1Gb ECC so dimm?
Go to www.crucial.com
They will run a test on your laptop and tell you exactly which memory will work on your machine
It is free and safe
Jan 29, 2010 | Toshiba Libretto U100 PC Notebook
Need to boot into BIOS to change IDE setting. No Floppy drive.
hi
To enter the BIOS during start-up press the ESC-key while switching power on
hope this helps :0)
May 19, 2009 | Toshiba Libretto 50CT Notebook
Toshiba libretto BIOS Reset
If there is a password that is not allowing you to reset the BIOS, I would recommend going to the following website and having one of the technicians use their proprietary devices that can unlock it for you. Im not sure if there is a charge but this may be the best solution to avoid any headaches. Just let them know there is a bios password preventing you from entering the BIOS and you need it removed and they should be able to help you from there.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?subs=tais
Mar 06, 2009 | Toshiba Libretto 100CT Notebook
TOSHIBA LIBRETTO 50CT NEEDS LINUX
Hello there
If you haven't got it already, download "Freespire" its a free linux download and really easy to use!!!!!!
It comes equipt with all the software you will need and a automatic updater which will download anything you need for the system.
Its easy to set up your internet and use office software (you can even view microsoft docs), with this you can even connect and chat to MSN, Yahoo etc
give it a go you will like it!!!!!!!!!
Kind regards
Dec 14, 2008 | Toshiba Libretto 50CT Notebook
Toshiba Libretto 70CT Notebook Logo
124 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
