Question about Car Audio & Video
Subwoofers cut out while driving but amp LED light is still on...
I have 2 ten inch kenwood subwoofers hooked up to a 450 mono Alpine amp which is hooked up to a pioneer deck. i have had this system for a little over a year and never had a problem with amp or subs, subs do not appear to be blown but have not yet been tested on another amp. all fuses are ok and all wires have been traced. i just can't figure out what the problem is. does anyone have any suggestions becuase i don't have the money to bring it to get fixed and really want my subs back. thanks
  • 45 Answers
To test if subs are blown push them in with your hand lightly and listen for any crunch noise if you hear one then they are blown
Posted on Jan 12, 2009
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
Wiring speakers to 2 ohm for most power
If you hook 2-4 ohm speakers in parallel that will divide Z into 2 ohms. That will pull a lot of power and drive hard the amp.
So if you have 4 channel outputs and had 8 speakers that would be the same. If you have 4 speakers and 2 outputs then 2 per output or if you have an odd number you would have to put one in series with the other 2.
Series means you hook output + to spkr+ then spkr- to spkr+ of the next, while parallel is keep the same polarity across them and in not so much of a loop. I hope this helps.
Sep 12, 2012 | Alpine Car Audio & Video
How to wire 2 alpine typre r 1242 to an alpine pdx1000 mono amp??
If they are single voice coil, just hook one up to the amp (bridged) like normal and run a jumper wire from the positive of the sub to the positive of the second one, then do the same for the negative....This will give you a lower ohmage, thus better bass!!!
Oct 19, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
Can you hook up two 12 inch subs to a 1000 watt amp?
need more info well you need to look at the subwoofer and see how many watts it can take and if it 2 ohm or 4 ohms single or dual voice coils and on your amp is it mono or 2 channel and what is the omhs for it
Mar 11, 2010 | Alpine SWS-1223D Car Speaker
How would you hook a alpine r12 dual 4 ohm sub to sony xm-1s mono amp
in parallel get both positives and both negatives together and wiring them to amp for a 2 ohm load. the sony xm1s is a 2 ohm mono amp
Dec 31, 2009 | Car Audio & Video
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
Mono amp
well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
Sep 26, 2008 | Kicker CVR12 Car Subwoofer
Blinking Led power light
I have a alpine MRP-M350 700 watts class D... i will ask if it can support 2 subwoofer a 1200 watts 10" JBL subwoofer?
Aug 22, 2006 | Alpine MRP-M350 Car Audio Amplifier
Car Audio & Video Logo
230 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
