Our brand new Kenmore Washer (model #20022) gets to the end of the spin cycle and stops. The "lid locked" light starts blinking. Then goes back to being on. Then both the "spin" light and "lid locked" light start blinking together. We cannot get the lid unlocked or the "cycle complete" light to come on.
SOURCE: Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
SOURCE: kenmore 92274800 repair ... WONT SPIN
My 110.92274800 did the same thing 1hr ago. Ive isolated the Problem it is a 15.49 cent problem from the manufacturer's website Part # 285753A. I am going to order and try and tackle the problem myself unless i can find it at a local Appliance Center that has it on Monday. Will keep you informed. Doesn't look to Hard. if you lean your Washer forward you will probably find 1/8 inch white peg looking plastic pieces. assuming you can hear the motor running on the spin cycle. You may lean the unit forward put it on spin and look at the motor to make sure it is still in operation. Hope this helps
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
SOURCE: Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
SOURCE: Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
