Question about Acer Extensa 5420-5687 Notebook
Where is the power on button on my Acer Extensa Laptop 5420-5687? I cannot get it to turn on
5 Suggested Answers
arquetteg
  • 37 Answers
SOURCE: Acer Extensa 5420 won't turn on, not a power/battery problem.
Just for the heck of it, try blowing out the cooling fan with some compressed air. If you have never cleaned it and the fan stops turning, the computer will go into a safe mode and not start up.
Ther should be a vent somewhere on the side of the laptop that vents hot air cooling the CPU. That is where you need to blow it out.
Hope it helps- just a longshot...
Posted on May 27, 2009
pagebor
  • 2785 Answers
SOURCE: rest bios Password acer extensa 5620z
plz check the link
Posted on Jun 22, 2009
SOURCE: Acer Extensa 5630 not booting
seems you have two problems
the ribbon cable on the lcd may be loose,
or need replacing ,
also check the pin in the dc jack if it moves at all or need to wiggle the ac adapter,it could be bad jack, but first make sure the ac adapter end is not bad, as the hole in the end gets bigger , it may not be connecting right
Posted on Jul 21, 2009
  • 26 Answers
SOURCE: Acer Extensa 5420-5687 laptop won't turn on
Okay, Here's the deal..... I recently had the same problems with my friends' Acer Extensa laptop and here's what I did to fix it. I narrowed the issue down to two culprits 1. Overheating, 2. Defective Motherboard. I have fixed the problem but I takes time, patience and some technical ability which may not be available to some. :( (Swapping out the motherboard MAY fix the problem but if the defect is in the manufacturing process then the problems could return). Here's how I fixed it... While in the process of disassembly I noticed a small electrolytic capacitor that had seemingly broken off and had become wedged between the frame (<ital>very lucky! this gave me the clue I was looking for!</ital>). This made me think that it had broken off the motherboard. I proceeded to disassemble the laptop and found the location of the missing capacitor (there are two located right next to each other on the board) and was able to re solder the capacitor back onto the motherboard (could it be a manufacturing processing defect thats causing these to break loose? ). Mine was broken off due to what looked like bad solder joints. Your capacitors could still be attached but have weak solder connections. Also while i had access to the motherboard, I used the opportunity to clean and re apply the heat sink compound to the CPU and thoroughly clean the fan vents. I then reassembled the laptop and EVERYTHING has been running fine now for the last 3 days. Total time was about 4hrs and it cost NOTHING to repair. GOOD LUCK :)
Posted on Mar 14, 2010
SOURCE: Acer extensa 5630ez won?t turn on.
Can you give a location of R138?
Is it on the easy side? E.q. the side of the motherboard wich is accessible by removing the bottom plate? I see Q24, located close to CPU. If possible, post a picture of R138, with some components visible.
Posted on May 11, 2010
My acer laptop extensa 5620 will not turn on,it is totally dead with no lights showing and no sound coming from the laptop, i have taken the battery out and plugged in the power cord and still nothing
My Laptop wont turn on [Solved] - CCM
ccm.net > Forum > Hardware > Laptop
Nov 13, 2015 - Hello,i need help.my acer extensa 5630ez wont turn on.i tried charging it for hours.it still wont turn on.when its plugged in, the battery led light ... My acer laptop wont start up!!! [Solved] - CCM
Jan 10, 2015
Connecting an external monitor to my Acer [Solved] - CCM
May 3, 2013
Mass storge controller acer extensa 5620 [Solved] - CCM.net
Apr 27, 2011
More results from ccm.net
Acer extensa won't boot. FIXED !! - YouTube
? 0:28
https://www.youtube.com/watch?v=Tb8hzSqWnjs
Apr 1, 2011 - Uploaded by Gen
Watch the fix i used here http://adf.ly/Pnk8u Acer extensa 5420won't boot. ... MADE THE LAPTOP HOT AND TURNED IT ON AND IT WORKED!
Acer Laptop Stops Powering Up- Wont Turn ON - Tech Support Forums ...
www.techimo.com > Forum > PC Hardware and Tech > Technical Support
Jun 5, 2010 - 11 posts - ‎3 authors
Dec 21, 2015 | Acer Extensa 5620 Notebook PC
Acer extensa 4620z whe i shutdown laptop it's shutdown but the screen power still remains on untill i hold the power button to off , please help me
It seems that your computer needs to have a reinstall of your original setup, because the driver that tells it to shut down is not cooperating. Hopefully you have your original dvd/cd.
Nov 20, 2012 | Acer Extensa 4620 Notebook
Acer Extensa 5235 wil not power on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Extensa 5235 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Extensa 5420-5687 Notebook
Acer extensa 5620 no signal and the power on and off three times and go off
Hi
I understand from your short ( very short ) words that the laptop won't start.., if so :
Please remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON,
Please tell us your results
Good Luck
May 14, 2011 | Acer Extensa 5620-4677 Notebook
System cpu fan cycles on and off 2 or three times and no display when you turn it on. ?
try to turn off the laptop and remove the battery and the power cable. Then press and hold the power button for 5 secs. Then reinsert the power cable and battery on to your laptop.. Turn on the laptop, and if the cpu fan cycles on and off, that means there is problem with the fan and also the power supply of your laptop. Call Acer to replace the power supply to stabilize your laptop's electricity...
Dec 20, 2010 | Acer Extensa 5620 Notebook PC
I turn on my laptop and it's dim. I press the FN
This is a Function of the laptop,you need to adjust your Power Settings. See the PC, does that to save Battery power, it will always be brighter, generally, on the Wall supply. You may need to set up a profile for both.
Apr 01, 2010 | Acer Extensa 5420-5687 Notebook
May 26, 2009 | Acer Extensa 5420-5687 Notebook
Acer Extensa 5420-5687 Notebook Logo
140 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
