Question about LG Dishwashers
LG LD-1403W door latch broken, can not open door
Door latch has disintegrated. Door is shut. Cannot open it. Is there a way of getting door open without the latch?
  • 833 Answers
SOURCE: dishwasher door latch
Check for a couple of screws to the left and right of the latch handle. Remove them and the unit should slide out and allow you access... By the way...if they are loose, tighten them first...you may just fix the problem.
Posted on Dec 09, 2007
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
here2helpBSH
  • 27 Answers
SOURCE: Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Posted on Mar 19, 2009
SOURCE: Amana Dishwasher door will not open. Latch you grap is very loose
We have the same problem and I bought the latch locally for $26.00 now trying to figure out exactly how to get the door apart to replace.
Posted on Mar 04, 2010
Lg LD-1403w dishwasher stops mid cycle
Most likely the water temperature is not reached as required and the dishwasher times out and stops without draining the water. It is likely the inlet water temperature is not adequate or if only using cold water the thermistor or the water heater are faulty.
Look for part M083 in the diagrams at the back of the service manual attached. you can also perform some diagnostics as shown in there but be very careful about the sequence otherwise you may flood or damage the dishwasher components.
http://www.jordansmanuals.com/ServiceManuals/LG/Dishwasher/LD1416T/LD-1416T%20Service%20Manual.pdf
Aug 06, 2014 | Dishwashers
My LG 1204W1 door will not close. The latch in the inside of the door at the top seems to be 'locked' making the door bump on the metal part that sticks out from the top of the door frame on the...
Hi there Bushx, sound to me like the door latch is in the closed position. you should be able to feed something into the catch and pull it back out to the open position. Please let me know if this helps regards Gary
Jul 17, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
I hav a lg Dishwasher model # LD-14AW2 the problem
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
Jul 07, 2010 | Dishwashers
LD WD1238C Door is Locked shut tried every trick you can think of including giving it a little kick
often on the upper grade washing machines, the components are a little more sophisticated. Possibly once you have removed the top lid, you will see the door latch from the back. some of the latches have a drawstring that you can pull which mechanically releases the door and opens. If you are able to before getting into stripping the wachine, gie it a quick cycle run and let it complete the cycle, Then try and open it. go from there.
May 19, 2010 | LG WD-1280FHD Front Load Washer
Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Nov 28, 2009 | LG Dishwashers
LG modelLD-1403W dishwasher. The bottom spray arm
The wheels on the bottom rack could be broken or collapsing..or the rack is distorted or bent..or the spray arm is not attached correctly or is damaged.
Nov 08, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Feb 15, 2009 | KitchenAid KUDR25 Dishwasher
Door won't latch to LG LDF6810ST
You have to pull out your unit about 3 inches to get to where the latch is screwed in. It is a phillips screw. The part number is 4026DD3001A. In the meantime to keep it closed you are going to have to get creative..
Sgt 48
May 12, 2008 | LG LDF6810 Built-in Dishwasher
LG Dishwasher Model LD-1403W gets stuck and stops on rinse cycle leaving water in bottom of machine. I have stripped it down and emptied it, made sure filters etc are clean but to no avail
LG Dishwasher LD 1403W. We have cleaned it and when it gets to the heating cycle after running right through to nearly the end, it trips all the electricity and stops everything. Its only 3 years old and hubby thinks its the heating element but between $200=$300 to fix.
Apr 10, 2008 | Dishwashers
Dishwashers Logo
66 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
