Sumsung lcd monitor smps top 247f bund , fuse opend
  • 3,267 Answers
  • That is a problem of smps
  • check the fuse inside the smps
  • check the component which blows the fuse e.g.diodes transistor
  • if faulty replace it
Posted on Dec 29, 2012
Power suply led lamp dosent snine, the screen is blank all time?!
yes it always happen to sumsung LCD, but don't you worry, just follow my tips to repair your LCD MOnitor. Click here for the tips.
Aug 09, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
I have sumsung monitor 740N, problem disply time is 4 sec only,i check the pcv board all capacitor are ok.pls help to solve this.tnx
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=740n&kategoria=&kat2=all
How is the DC voltage for the backlight inverter circuits?
Caps can look OK but can have high ESR.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Aug 04, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Hi.my flat screen is not powering up
pkawinzi, Fuse or switch-mode-power-supply has failed. If internal fuse ok, SMPS may be in full shutdown mode. Unit will need you or qualified ccfl back-lit lcd monitor tech to open unit and inspect smps printed circuit board if warranty has long since expired. All CCFL back-lit lcd monitors are of same basic design and operation. Just do some reading in the fixya profiles of tech's " buddymc" , "budmrtn" , and my old file "louie12fix" for all you need to know to make decision to repair (DIY or out-source repair) your unit. You only stated "now" info!!! A little bit of past performance "history" of your unit would have been more helpful.
12fixlouie
May 12, 2010 | LG Flatron L1715S 17" LCD Monitor
My LG Flatron L1515S 15" LCD goes on blank scree(black screen) after displaying for 2 to 3 seconds and when i switch off and switch on monitor, again it is going blank after displaying for few second....
sitaramjava, Problem not new one!!! When lcd screen goes "black" point bright flashlight (torch) 1" (3-4cm) from lcd panel to determine if you can still see desk-top icons!!! If icons are visible, unit SMPS is in partial shutdown mode. If not visible then SMPS is in full shutdown mode. You or qualified CCFL back-lit lcd monitor technician will need to make repair to units internal SMPS/ CCFL inverter supply. Your monitor isn't any different than any other brand in it's basic design and operation!! Read my and other CCFL backlit lcd monitor technicians FIXYA profiles to see if you can repair it. 12fixlouie
May 04, 2010 | LG Flatron L1515S 15" LCD Monitor
My Lg Flatron switched off
  • that is a problem of smps
Apr 15, 2010 | LG Flatron L1510S 15" LCD Monitor
Hi I have an Acer AL1916 that is not powering up, there is no light on the switch, is there anything I can do, like fuses to check etc? Regards Alan
Sorry no fuses that can be changed. Often it is just the power supply going on the fritz, take it in for repair, due to the cost of monitors repairs are usually very reasonable, as long as you find, a place that specializes in Monitor repair, it will be OK. Anyway you can always ask for a "Quote" and decide as to repair or replace,
Apr 05, 2010 | Acer AL1916W 19" LCD Monitor
My sumsung tft is no display
I will assume that you already try thus monitor with other PC with the same result.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Samsung SyncMaster 17" TFT LCD Monitor
My monitor is blank. No power when connected to computer. What went wrong It is a benq model
filmorepetty, The "switch-mode-power-supply" has gone into SHUTDOWN mode because it has detected a fault with itself or another circuit. Or it could have just blown a small fuse on the circuit board of the SMPS. Will the pilot lamp light-up? Did it have a clean, bright, crisp, image displayed on the lcd panel the day before? How old or how many total (approx) "ON" hours of use has it seen? Do you know that 98% of lcd monitors use "cold-cathode-fluorescent-lamps" and an accompanying "electronic ballast" circuit to generate the WHITE LIGHT needed for you to see the pretty colors on the LCD Panel?? Same basic lighting technology as the new screw-in socket curlie-Q CFL light bulbs! Only your monitor's lamps are thinner and straight and hung on the rear of the LCD panel. A failure of the ballast circuit could cause SMPS to shutdown. I suggest you visit some other websites for more info on what other owners are doing to try and repair BLACK SCREEN lcd monitor problems. The first place to go would be YOUTUBE and search and view the longer 6-12 minute video clips of "LCD monitor disassembly" and "LCD monitor repair" just FYI and to know what you are dealing with??? Your unit could also have FAILED electrolytic filter capacitors on the SMPS printed circuit board. I'm 12fixlouie Bye for now.
Dec 04, 2009 | Dell E153FP 15" LCD Monitor
What kind of capacitors should i use to replace the 180uf 30v ones
Electrolytic capacitor usually blown up the top only in you can still reading the value in the body of the capacitor like the voltage and micro farad example 400V/33UF that's the value of the capacitor
Apr 15, 2008 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
