Question about LG Refrigerators
Manual for a LG express cool gr-391sca - LG Refrigerators
4 Suggested Answers
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
SOURCE: LG express cool no frost
I had the same problem - repairman was just here - it was the defrost motor was burnt - the freezer had frost buildup behind the panel, which was not allowing the cool air to circulate to the fridge compartment
Posted on Aug 16, 2011
imufo2
  • 3773 Answers
SOURCE: LG Refrigerator does not cool.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Aug 24, 2011
Lg fridge GR-B3993LQ is not cooling
Make sure that the thermostat is working and that the compressor and associated fans are working (getting Power).
If both units are working and still no cooling your evaporator could be frozen because the defrost timer/element is not working. Worst case scenario is that you may have developed a small leak and lost refrigerant.
Mar 11, 2015 | LG Refrigerators
LG Express Cool Turbo GR T542G Stopped cooling
it should run when the comp is on and the unit is calling for cooling, you most likely need a new fan for your unit.
Aug 10, 2013 | Refrigerators
Lg express cool turbo gr-t452gva water build up in fridge
Drain pipe is in the freezer below where the fan(s) are. You may need to take a cover off to get to it.
Mar 20, 2013 | Refrigerators
WHERE DO I GET A MANUAL FOR THIS REFRIGERATOR LG GR 642AP
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/GR-642AP-_E
You need to have acrobat reader to view this.
Good Luck!!
Thanks!!
Aug 17, 2010 | LG Kitchen Ranges
Keyboard layout, can't find backslash
It's there, somewhere.
Look carefully in each "corner" of the keyboard (top-left, top-right,
bottom-left, bottom-right).
If your keyboard has an ALT GR ("Alternate Graphic") key,
and some keys have *MORE* than *TWO* labels, e.g., Euro & Dollar & '4', then hold-down the ALT GR key, touch the '4' key, and release the ALT GR key.
Jan 14, 2010 | LG E500 Express Dual Series Notebook PC
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
Hot areas around doors on LG fridge
Nov 18, 2007 | Refrigerators
Refrigerators Logo
598 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
