Question about Apple Harman Kardon Go Play Ii Portable Loudspeaker Dock For Ipod And Iphone
Unit will no longer power on after only owning for 4 mths. AC power strip lights up, but makes humming sound. Unit will charge ipod, so it's getting some kind of power, but unit will not power o
    Sergeant:
  • 256 Answers
Take it back to where you got it from
Posted on Dec 05, 2012
Receiver keeps going to standby
I don't know about the newer receivers but this sounds like an arching OFF/ON power switch that was a problem on Pioneer receivers years ago. I would bypass the switch and see what happens.
1. Unplug unit from wall.
2. Jumper two wires going to off/on switch using alligator clip with insulated boots on clips.
3. Plug amplifier into disconnected circuit breaker/fuse protected AC strip.
4. Plug AC strip into wall outlet, turn AC strip switch ON and see if problem disappears.
Feb 20, 2013 | Insignia 200W Stereo Receiver
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
A/C runs three to four minutes; shuts off. Press, reset button, on the power cord (note: a/c inserted in power strip; and I've tried other outlets, as well).
The Power Strip may just be the problem. As far as I know, there are no manufacturers that approve the use of a Power Strip, for their AC unit to be plugged into. I know of two units, that had their electronics fried, while being plugged into a power strip. Which brings us, to the point, that your AC may already being showing the results of being plugged into a power strip. Most don't encourage an plain extension cord
Plug the unit directly into a wall outlet and try lowering the temperature by 3 to 5 degrees F, to see if it will run longer. Also, check your air intake filter and clean it, if necessary.
If the icontinues to turn OFF prematurely, it may be time to decide whether to repair or replace.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Kenmore Heating & Cooling
I have a goodman gsc13 ac unit about 4 year old. When the temp gets around 90 or above outside the fan on the unit starts but the compressor does not. I had service check it out but that day they were...
It sounds like the unit may be over charged. Make sure the outside coils are clean and you have plenty of airflow coming out of the top of the outside unit. What could be happening is, when the temps get higher outside, so do the pressures in the system. The compressor has a thermal overload protection that will kick the compressor off if it gets to hot, which if the compressor is over charged, it will work twice as hard, over heat and shut off. You would need a technician to come out and get the refrigerant charge back to normal. Another thing that could be happening is a weak or faulty capacitor, which is a small round or oval metal object, found in the electrical compartment on the unit. This are fairly simple to change out if your comfortable with electric. I've also had to put what's called a hard start kit on compressors with the same problem, new and old. The hard start basically gives it that extra boost of power to get it up and going. I would start with the refrigerant charge and go from there. The electrical "humming" sound that you hear unless you turn the breaker to the furnace off, is the contactor on the outside unit having a call for cooling. The 24 volts come from the furnace, to the outside unit, and pulls the contactor in to power the unit with the 220 volts supplied. It is normal and you don't have to worry about that at all. I hope some of this helps and good luck!
Jul 05, 2011 | Heating & Cooling
When the AC fan shuts off, the compressor appears to be stuck. It continues to make a humming sound as though it is running. If I remove power and return power it hums momentarily and then shuts off. Is...
Yes, not good for compressor to stay on after being shut off, and hitting the breaker to stop it is a good idea. Sounds like you have a faulty/sticky relay. Not an expensive part, and shouldn't take any longer than 1/2 hr to change. Have a technician, or electrician look at it and give them a model number of unit so they can make sure they have a relay with them when they come. That way, another trip back, as well as a service charge will be eliminated. You have capacitors in the same area, that are very dangerous to work around if not experienced, so make sure the person is experienced, to avoid shock from 250-370 volts stored in those capacitors.
Aug 07, 2010 | Dometic Rooftop RV Air Conditioner
I get a humming sound when the ipod is attached,
the hum comes from three possible sources, the power unit can cause it before failure, the amplifier which can effect one or more speakers or the interface board between the other two, the interface board and the power board are known problems to b and w, so if you have not already contacted service at b and w, then do so.
May 15, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
How to charge dvd plug in to ac get a red light some time yellow and do you charge with power switch on or off need a manual.
I have seen no rechargeable device that requires the power switch that lets the device function turned on. Often, it is mentioned that the length of time for a full charge will be longer if the unit is in use at the time since the unit and recharging function both require power and if the player is in use, it logically has priority over the recharging function. In other words, it should charge more quickly if the player is turned off.
Unfortunately, Initial's website: http://initialdvd.com/ is no longer in operation so finding the manual could be a problem. Initial Technology has sold a number of 'turkeys' in the US (we own an Ilo TV) and I think they no longer exist.
Jan 02, 2010 | Initial IDM-1731 Portable DVD Player with...
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Need Help
Press the middle key and menu key at the same time until the apple screen comes on. This will reset your settings but usually when my iPod does something funky like that I just do that and it's fine. If that doesn't work, contact your local Apple store.
May 02, 2008 | Apple iPod nano
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
Apple Harman Kardon Go Play Ii Portable Loudspeaker Dock For Ipod And Iphone Logo
202 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
