Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma ip3000 flashing amber 6 times
I checked the error codes on Canon website. Solutions for FLASHING POWER LIGHTS Issue: Alarm / Power light flashes orange 6 times consecutively (Inner Cover Open Error) None of these corrected the problem. Any help in solving this problem would be greatly appreciated!
1. ');includeTableSubmitItem(3716, 'Close the inner cover, then press '); return false;" class="midredlink">Close the inner cover, then press 2. Reset the printer 3. The iP3000 may require repair
  • 20 Answers
If the 6 flashes are accompanied by an on screen message #5400, this is a "Service Call Error" code.
This code indicates the following;
Internal temperature error [5400]
The solution to this is the following part replacementl
- Logic board ***'y (QM2-1548) *1
*1: Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or
more, also replace the bottom case unit (QM2-1205) or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257) when replacing the
logic board ***'y.
[See Section 3-3. Adjustment / Settings, (6) Service mode, for details.]
Good luck!!!
Posted on Oct 02, 2009
Service error 6B00.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Mar 18, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Ip 3000 canon showing service error 5100, tried to reset but still flashes amber. Tried nearly everything. Cartridges still full
Carriage error [5100]
Solution (Replacement of listed parts, which are likely
to be faulty):
- Carriage unit (QM2-1250)
- Timing **** strip film (QC1-4284)
- Logic board ***'y (QM2-1520)*1
- Carriage motor (QK1-0545)
Aug 04, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
Nov 04, 2009 | Canon Office Equipment & Supplies
I have an IP3000 printer and each time it is turned on it goes into error mode (the on light blinks amber 5 times then turns green for about 1 second then it flashes amber again
I. Make sure the printer is off but is plugged in
II. Hold down [RESUME] (Triangle pointed down) and hold down [POWER]
and wait 5 seconds or so.
Release [RESUME] but Continue to hold [POWER]. Double click [RESUME].
then Release [POWER].
Press [RESUME], than [POWER]. This should cause the printer to print a
simple diagnostic that'll list it's ROM number and list CDR SENSOR=OK
in red for the last line.
Press [RESUME] twice then [POWER]] to print off the second diagnostic.
Press [POWER] by it self to exit service mode and return to being a
printer.
Nov 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have a acanon pixma mp210.. amber alarm light
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My pixma iP3000 has flashing amber light error 6000 Canon say toss it-can i fix
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
5 flashes amber pixma ip3000 5 AMBER FLASHES PIXMA IP 3000
Try this link http://www.fixyourownprinter.com/forums/inkjet/27412
Stanr
Oct 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
1,165 people viewed this question
old marine
old marine
