Question about Whirlpool Duet GHW9150P Front Load Washer
How do I unclog the pump of a whirlpool washer?
    Sergeant:
  • 291 Answers
This is a pretty good video that goes step by step:
http://www.youtube.com/watch?v=2abTptUYXH8
There are many more YouTube vids for machines very similar to yours on a variety of subjects. Check them out. Hope it helps.
Posted on Dec 08, 2012
How do you clean out the drain pump maytag centennial washer
Maytag & Whirlpool & Kenmore Washer Pump Repair ...
? 3:44
https://www.youtube.com/watch?v=97rBObh_3mQ
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Repair your own Maytag Top Load Washer which has the following ... Took me awhile to unclog as an entire ...
Washer Won't Drain - Pump Clogged with Sock - Repair ...
? 1:53
https://www.youtube.com/watch?v=tHT7PmmFc9w
Dec 2, 2011 - Uploaded by Tomahawk DIY
Washing machine pump clogged with a sock. ... I searched hi and low trying to figure out why my washing ...
HE Maytag Centennial Washer Fix - YouTube
? 31:43
https://www.youtube.com/watch?v=CoTlOr3Gxuk
Nov 15, 2013 - Uploaded by mike3000ace1
So how do you open the washer to pull out the Manual? .... +mike3000ace1 Hi, I have a 2011 Maytag ...
Maytag Centennial Washer Drain, Transmission ...
Jan 05, 2016 | Maytag Washing Machines
My washing machine will fill up with water but it will not agitate or spin to drain the water all it does is make a humming sound like its trying to and if I let it hum for a while I start to smell...
This is most likely going to be something hung in the water pump. On this pump I end up changing the pump because it is hard to get it unclogged without damaging the pump. This page should help. http://www.appliance-repair-it.com/Whirlpool-washer.html
Sep 16, 2010 | Kenmore 22932 Top Load Washer
Not draining
how do i unclog the drain pump
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 Whirlpool duet washer, removed front panel unclogged restarted and still f21? Tech came in and had no idea said he smelled something burning, must of been his imagination.
ohh, duets are such a treat.
If the drain time exceeds eight minutes, “F21” will be displayed,
the water valves will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be
cleared and the machine will turn off after a maximum of eight
minutes.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
this is what Whirlpool says, but we have found that this doesnt always work.
Nov 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need directions to unclog my Whirlpool duet washer which is giving me a f21 code.
Empty the washer and get some towels...
  1. Unplug the washer.
  2. Remove the kick panel 4-8 screws along the bottom with a Torx 15 screwdriver.
  3. Directly in front of you will be the pump and the cleanout (large twist-cap).
  4. Pack towels under and around the cleanout.
  5. Turn the cap counter-clockwise and pull out.
  6. Remove any debris.
  7. If you have an additional cylindrical pre-filter, remove and clean it.
  8. Re-assemble.
  9. Plug in the washer
  • Note: If you see bubbles or foam in the cleanout, you're using too much soap.
Dec 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
take cabinet off and the pump is right there in the front of the motor.remove the top hose and the water will finish draining on the floor.reach in and you should be able to take out the obstruction.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
C1 Fault
code CL.(C1) This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem. Calypo washers do have a history of break downs within the drive system.
Dec 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Jan 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal De
