Question about NetGear Universal WiFi Range Extender Network Adapter
Cannot connect NetGear WN3000RP with wireless
Settings do not match for my computer.
  • NetGear Master
  • 27,725 Answers
If you use a Netgear router to broadcast a WI-FI (Wireless Fidelity) signal in your home, you can easily double the range of your network by connecting a second router to one of the LAN (Local Access Network) ports located on the back of the Netgear router. You can use a Linksys, Belkin, D-Link or even a second Netgear router to extend the range. Any router that allows you to access the router settings to turn off the router's DHCP server is usable as a range extender.
Complete a master reset on the router you want to use as an extender. Typically, routers have a reset hole located on the back or side of the router. Push a metal push pin into the hole until the lights on the router flash. Often the settings on routers have been manipulated to enhance a network connection. Resetting the router ensures you can access all of the settings and not encounter any issues when making the connection. Plug an Ethernet cable into one of the router's LAN ports located on the back of the router. Plug the other end of the Ethernet cable into the Ethernet port located Enter the router's IP address into an Internet browser Web address field. If you do not know the default IP address, reference TechSpot.com for a list of router IP addresses. Enter the default username and password for your router. If you do not know the default login information, reference Router Passwords.com for the default login information for your router brand. Access the DHCP server settings. Usually, this is located in the "Basic Setup" section of the router settings page. Turn off the DHCP server and then select "Update Settings." The location of the DHCP server can be located on a different page if the router is an uncommon brand. Access the "Wireless Setup" page and change the SSID to match the network name you use for your Netgear router. Select "Update Settings" to save the network name. This allows computers to move from the Netgear router to the router used as a range extender without requiring a second wireless profile being set up on the computer. The SSID could be located on a different page if the router is an uncommon brand. Access the "Wireless Security" page and update the router's password to match the password used on the Netgear router. If you do not secure your network, skip this step. The wireless password could be located on a different page if the router is an uncommon brand. Remove the Ethernet cable from the router and the computer. Plug one end of the cable into the WAN (Wide Area Network) port located on the back of the router you want to use as a range extender. Plug the other end of the cable into one of the LAN ports located on the back of the Netgear router. Hope this helps
b>
Posted on Dec 11, 2012
    Scholar:
  • 60 Answers
Cannot connect NetGear WN3000RP with wireless"Settings do not match for my computer."
Going only by this one clue, it appears that you must delete the network that was originally set up & start again. This is done in the network & sharing area. Look for "manage connections" or "manage adapters"- something like that. You're looking for the list of available networks. You will see your own network name in a list format. Delete it.
Now, you can set up your new hardware & it won't complain about "wrong settings in your computer".
Cheers!
Posted on May 11, 2013
I ask to join and they ask for password and i typed in password and it will let me join
Try using the same security settings as your existing network by selecting the "Use the same security mode" check box when setting the your extender.
Jul 02, 2014 | NetGear Universal WiFi Range Extender...
Hg532 modem router
You can only set it up using WPA protocol over the network.
Otherwise you have to use WEP and login wirelessly to set it up.
See the manual here
http://www.downloads.netgear.com/files/GDC/WN3000RP/WN3000RP_IG_13APR2012.pdf
Apr 05, 2014 | NetGear Computers & Internet
Your connection is limited
What router and where is it that you are connecting the Extender to? An extender is not a router. You need a router to extend the wifi signal from.
Mar 22, 2014 | NETGEAR CONSUMER New - Netgear Wn3000rp...
How to reset my wifi range extender wn3000rp
There is normally a hold the size of a paper clip you need to press and hold it with a paperclip for 30 seconds
Mar 10, 2014 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I can not gem=t my WN2500RP to connect to my Netgear Router
To properly set up the WN3000RP you first have to push the WPS or Push 'N' Connect button on the router-WN2500RP(on the back of the router between the reset and the wired connection slots) and then the Push 'N' Connect button on the extender. It should negotiate and establish a connection between them.
Sep 28, 2013 | HP Netgear Wn3000rp Ieee 802.11n - Draft...
Netgear and anti virus software
Please describe your problem... which anti virus your using ?
Apr 12, 2013 | NETGEAR CONSUMER Wn3000rp-100nas netgear...
When I try to connect to my netgear wireless network it says" The settings saved on this computer for the newtwork do not match the requirements of the network.
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Oct 26, 2011 | NetGear WNR2000 Wireless Router
NetGear Universal WiFi Range Extender Network Adapter Logo
1,224 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
