Question about Rainbow E series Canister Wet/Dry Vacuum
Manual for e2 type 12 rainbow vacuum - Rainbow E series Canister Wet/Dry Vacuum
4 Suggested Answers
SOURCE: Rainbow E2 2 speed vacuum motor whines at startup
I used to sell rainbow vacuums and this latest 2 speed model does whine when it is first turned on. So you definately have nothing to worry about. I believe this is due to the fact that this motor is much more powerful than in the previous 1 speed E series model. I finally just purchased a 2 speed model after many many years of wanting one. Good luck to ya and enjoy your clean house!
Posted on Mar 21, 2010
  • 52 Answers
SOURCE: rainbow e2 2 speed vacuum shuts off after 5 minutes of vacuuming.
2 speed E2 models have a circuit board inside that controls the machine. It sounds like this controller board may be bad. The unfortunate part of this is that the board is not only very expensive, but it is only available from an authorized Rainbow service center.
Use caution if you decide to work on this yourself or if you take it to a service center that is not famliar with these models. The circuit board mentioned above is susceptible to damage from static eclectricity discharge. The static you generate from just walking across a carpet could make this board useless. So, if the original problem is not the board you could make the problem worse.
Posted on May 21, 2010
  • 4 Answers
SOURCE: Lost the manual for my Rainbow SE Vacuum. Is
Try this site.
http://www.rainbowsystem.com/rainbowsystem/manuals/
Posted on Dec 31, 2010
Our rainbow e2 black type 12 vaccum was meant to be used on 110v and was plugged into a 220v, what part needs to be changed to convert the machine to work with 220v
nothing that I can guess at but changing the motor to a 220 . might be more cost effective to purchase a new vacuum cleaner .or use a 110 convertor for your outlets
May 22, 2016 | Rainbow Vacuums
Rainbow turns on for a second or two then quits and won't turn back on.
If you have the model Rainbow E-2 eSERIES then the Motor Rainbow 120v could be going bad. This will trip the auto reset until it cools down.
If you have an E2 Type 12 Rainbow, then the Controller Asm 120v e2 Silver Gold could be going bad.
Our technical support team is available if you need... Contact Us
RainVac
Mar 24, 2016 | Rainbow E series Canister Wet/Dry Vacuum
Where can I get a step-by-step procedure for rewiring?
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
Nov 04, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
Where do I get an adapter for my rainbow shampooer
This really depends on what Rainbow you have and which Aquamate you are using. There really is not an adapter for the Aquamate. The newest aquamate out there is for the E2 type 12 black that came out in 2012.
There is a modification of this aquamate to fit older E series vacuums (comes with a cord) , but you will need to have an electrified hose made for water pick up to use. You can find that aquamate here
Rainbow AquaMate 3 carpet shampooer
GoodVac
800-775-6586
Mar 05, 2015 | Rainbow Vacuums
Rainbow vac turn off after been working
If it is an E2 Type 12, it could be the controller. If it is an eSERIES, it could be the thermal cutoff....call our tech. support and we can help you figure out the problem with a few tests...www.rainvac.com
RainVac
800-523-0510
Mar 08, 2013 | Vacuums
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Have a rainbow e-2 that was running and quit.
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
Thank you,
Ralph
Apr 25, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How do we remove the motor filter on our Rainbow vacuum. It is an E2 type 12.?
you have to completly disasemble the vacuum, if your not real good with a pry bar to pop the plastic apart you might want to take it to a shop they are pretty tricky
Nov 04, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
641 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
