Question about Dishwashers
Am trying to source a Dishlex Global DX300 Dishwasher manual as PDF.
Have moved in to a house with a Dishlex Global DX300 Dishwasher with no manual and the writing on the buttons have faded - how do we turn it on and select programs?
5 Suggested Answers
SOURCE: Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Posted on Sep 12, 2008
SOURCE: Dishlex Global 300 - stopping mid cycle
This problem is common to both the 300 & 310 models. The flashing Fast light indicates a blockage in the water supply. I fixed this by:
- disconnecting the dishwasher
- checking for blockages in the input hose filter (there were none)
- removing the bottom of the dishwasher (two screws at the front)
- looking for the translucent plastic bucket thing attached to the side of the main assembly
- unclipping it from the main assembly and removing the white hose attached to it
- flushing 5 years worth of evil gunk down the sink (you need a small brush or piece of wire to get it out
Gabriel
Posted on Jul 28, 2009
  • 713 Answers
SOURCE: dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Posted on May 22, 2011
  • 960 Answers
SOURCE: Dishlex Global 300 Dishwasher -
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Posted on Jul 26, 2011
Testimonial: "Excellent info - saved me a packet"
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishlex Global 200 won't fill with water
Shut off the water to the dishwasher. Take the line off where it connect to the dishwasher. Get out a bucket (dishpan, etc.) and put the open line into the bucket, turn on the water. Does it have a good stream? If not the problem is in the supply coming from your house. If the stream is good, house water is fine. Connect the supply back up, find the electrical solenoid that the water feed goes to and disconnect the line on the other side of it. Try turning the dishwasher on with bucket catching water, when the solenoid clicks on is there a good stream of water? If not either solenoid is bad, or maybe there is a filter (screen) before the solenoid that needs cleaned. If there is a good stream after the solenoid, then the controls must be bad telling it to shut off too early.
Dec 25, 2011 | Dishwashers
I need a free manual for the dishlex global 450. Most sites request you sign up.
Here in the state, Dishlex is the same as Electrolux. I would think the models are the same,except fort he number. Take a look.
http://www.electroluxappliances.com/kitchen-appliances/dishwashers
Oh yes here is the Australian manual download site also:http://www.dishlex.com.au/downloads.html
Hope this helps.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Feb 20, 2011 | Dishwashers
I want instruction manual for dishlex global 300 dishwasher
Happy New Year and welcome to FixYa, I am Kelly.
It took a while to locate the manual as there was not a model number. The model number I located was an Electolux DW300XA and the manual can be found here:
http://manuals.appliancesonline.com.au/dw300xa/dw300xa_product_manual.pdf
If this is not your model number, please respond wth your model number and I will look for the correct manual.
Thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Dishwashers
I would like to download a user manual for dishwasher dishlex global 300 DX 300 WA - thanks Lou
I think I have a PDF 300 Manual. Please email at mexeter@westnet.com.au and I will email it back.
Rergards
Mark
Sep 02, 2010 | Dishwashers
Dishlex Global 300 dishwasher no manual
Try Googling your dishwasher for the proper manual or see if you can go online and download it from the manfacturer
Jan 23, 2010 | Dishwashers
Aug 24, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
Owen Barnes
