Question about Traxxas T Maxx 3.3 Monster Truck
Have a glow plug light and motor light wont start
Was running great had no issues it stalled while running it wont start i think its the starter all lights are on wont crank
    Master:
  • 482 Answers
If you cant turn the engine over with the pull starter, you have locked up the engine by running it too lean and hard, a rebuild is in your future
Posted on Mar 07, 2013
3 Suggested Answers
  • 88 Answers
SOURCE: starting problem
Could be a bad glow plug. I would start there, they are inexpensive and easy to change.
Posted on Dec 11, 2009
micromend
  • 748 Answers
SOURCE: my revo is getting fuel light on start remote are
Hi
You've checked the glow plug externally to see the wire get red? If so, as long as you've got fuel and fire then it has to start. My guess here is that you have either a bad glow plug, low batteries, fuel air leak or clogged pressure line. Put a charged battery into the starter. Remove the glow plug and try to start - fuel should spurt up through the glow plug opening. Now connect the glow plug and touch it to the engine. Try to start and you should see the glow plug wire glow red. (do this only for a second. Now disconnect the pressure tap from the muffler and try to start. All else fails, replace the fuel line to the carb and the pressure tap. Your carburetor can leak air through the rubber gasket . Also, Traxxas fuel tanks have a cracking problem. Good luck
Posted on Apr 14, 2010
Why will car not start from key? Just turns over until battery drained, seems too sluggish to start
Has the fuel pressure been tested? Are you sure the ignition starter switch is ok and doesn't have an open that causes a stall out when the key is released. We do not have the diesel engine in this country so repair info is limited. You need to stop guessing and consult an expert, you have replaced parts that I would never replace for this kind of issue, a total waste of money and your time.
Oct 01, 2016 | 2003 Ford Focus
1999 VW jetta TDI
p1248 is in the same error codes as the rest now i have been a mechanic for plenty of years and i will tell you it will be the glow plugs they have a certin limit to glow to start the car if they are worn or nearly gone they wont hold all the fire in them ,,,,Injection start control deviation means the car is not getting even to kick start it it maitanes and shuts the engine down if there is a problem i suggest you changed the plugs and see how you go here is a link to see http://www.patentstorm.us/patents/5778852/description.html
Sep 20, 2008 | 2000 Volkswagen Jetta TDI
Glow plug light stays on, engine turns over but won't start
glow plugs dont last for ever
have them visually inspected
they need to heat up to spec or motor wont start
what motor or vehicle ?
May 31, 2016 | Cars & Trucks
51 ford focus 18 diesel wont start
THE GLOW PLUGS/ OR COIL PACK. NOT GIVING ENOUGH POWER // JUICE TO START THE MOTOR STARTER?/ IS STARTER GOOD?
Dec 24, 2014 | Ford Cars & Trucks
Jeep 96 dies sometime going down the road and wont start sometimes. will start after 10 miles at times and 24 hrs sometimes. the dash says check gauges. help woman alone need advice
Fuel pump intermittent, check for fuel pressure before dropping the tank to renew pump.
Otherwise check electrical connection at battery, and make sure you do not have an open circuit.
Loss of connectivity could cause this issue, failed fuel pump sometimes work, but are not reliable.
You should see 30-45 psi at fuel rail, and the regulator should bump pressure 5 psi when reving the motor. Higher pressure indicates failed regulator.
Jun 23, 2014 | 1996 Jeep Grand Cherokee
1986 ford f350 won't start
The solenoid click sounds very strong, implying that you have a charged battery and the ignition circuit is functioning out to the solenoid. Suspect an issue with the starter motor. Is the starter motor installed and connected properly?
Aug 11, 2013 | Cars & Trucks
8n ford wont start when hot,plugs are dry,ethar
can u send the license key for 355664007645462 this will be help from u
Dec 11, 2009 | Ford 8N Tractor
Glow plug warning light flashes on and off but wont turn over
your glow plugs are probably bad change your glow plugs
Dec 06, 2009 | 2000 Suzuki Grand Vitara
I have a 1994 2.8ltr Diesel (4M40 Mtr), Delica, that conks out
try changing all the heater plugs there are warn out by now,,if it realy dont like starting up on cold days do what i do,,, give it twice the heat up time,,,,,
turn on the kye wate till the heater light go's out then quikly switch it off and turn it back on for a re-heat before trying to start it up,,,also try changing the glow plug heater relay,, it should hold the glow plug heaters on for about 30 seconds after the light has gone off even if the engen has started and is running
but i bet its not doing this? giving twice the heat takes less out the battery than cranking it over and your not wearing out the starter as well?
doing this to my old girl gets her going every time!!!!!
Oct 26, 2009 | Mitsubishi Passenger Cars & Trucks
Traxxas T Maxx 3.3 Monster Truck Logo
167 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
