Question about PPE 2005 2006 2007 GMC DURAMAX DIESEL HOT XCELERATOR ET
05 duramax loses power under load
Runs great until loaded
2002 Xlt 800 runs great on the lift, then bogs and dies under throttle in water
it is possible that it is a carby problem or pump diaphragm
the problem indicates insufficient fuel when under load from the pump ( not under load when out of the water)
Jul 10, 2016 | Covercraft Personal Watercraft Cover -...
Engine overheats under load
There are quite a few reasons the engine could overheat other then a failed cooling fan clutch. I wonder if the fan is always on because the engine is always running hot?
This condition may be caused by any of the following possibilities:
• Installation of an aftermarket grille.
• A plugged charge air cooler.
• Fan clutch not operating properly.
• Drive belt slip.
• An overfilled transmission.
• Turbocharger not operating properly.
• A plugged air filter
Hope that helps........
Aug 27, 2008 | Chevrolet Silverado 3500HD Cars & Trucks
Chain motor losing drive under load,not stalling engine,pretension nut is tight ???chain motor is making a hydraulic squeal when chain stops under load?
Is the chain too tight..!? You should be able to roll the chain forward using a combi spanner without too much effort and it should stop and not run on..
Other reasons a saw will lose power under load are as follows; plugged air filter, blocked fuel filter, tank vent, air leak between tank and pump, pump diaphragm damaged, main jet blocked.
Mar 04, 2015 | Garden
OBDII Codes 2006 Chevy 2500HD w/ 6.6L Duramax "Truck started losing power when warm, when cold for the first 10 miles or so the trunk runs great."
You need a dealer, there is a real problem going on here, way over the head of any home do it yourselfer. The main reason is the special tools required to interface with the control modules that are throwing these codes
Jun 29, 2017 | 2006 Chevrolet Silverado 2500HD 2WD
Engine loses rpm
What is the year make and model?
Feb 19, 2014 | John Deere Kawasaki K Series Air Cooled...
I have a 05 Chevy Duramax Diesel that is having issues starting. Randomly it will just not start. Turns over fine, but no start. Acts like it is out of fuel, but there is fuel. Let it sit a while,...
I am currently having the exact same problem with my '05 duramax. today for the first time it even died while driving and then would not restart for 5 minutes. If you figure this out please let me know. My email is travis.brown.23@hotmail.com
Im taking mine back in to have it looked at tomorrow.
Oct 23, 2010 | 2005 Chevrolet Silverado 2500HD 2WD
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Generator loses power under a load
A microwave oven is a fairly "reactive" load due to the current limiting transformer. You should probably have at least a 3000 watt generator to run a microwave oven.
Sep 28, 2009 | Electrical Supplies
1990 454 mercruiser misfire under load when warmed up
Running on a stand is not the same as running under power...In the water, you are essentially running on a dynomometer (dyno is a big water brake) If you can prove that the module isn't putting in enough advance, it would be doing the same thing that I mentioned with the damper, only for a different reason. So...you're likely on the right track. (rather have a points setup out on the water...anything goes wrong, you fix it without a tow!!!!)
Good luck
Aug 29, 2009 | 1988 Chevrolet Suburban
PPE 2005 2006 2007 GMC DURAMAX DIESEL HOT XCELERATOR ET Logo
96 people viewed this question
Top PPE Office Equipment & Supplies Experts
john h
Ted Maxwell
Are you a PPE Office Equipment and Supply Expert? Answer questions, earn points and help others
